Question about Coffee Makers & Espresso Machines
I bought a keurig from Canada and tried using it in Dubai (Middle East). Used the right plug but no transformer. The Keurig came on for a minute but then died and never worked again
    Sergeant:
  • 330 Answers
Te voltage system in Dubai is 220-240V. It's only 115-125V in Canada. If the Keurig is fuse protected, it could be repaired. If not, you might have fried some components inside.
Sorry, that's all the help I can give you.
Posted on Oct 15, 2013
rickzilla
  • 706 Answers
SOURCE: Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
Posted on Aug 31, 2008
  • 3600 Answers
SOURCE: keurig B70, the my k cup , weak weak coffee !!!!!
It is best to take it to the store you bought it from and have them fix it and watch or replace at no cost to you. Tell the store what they said to you and have them show you how to do it. If you work on it and break it you own a broken machine. Hope this helps.
Posted on Aug 26, 2009
VtToolMan
  • 704 Answers
SOURCE: Trying to run Keurig for first time. Shuts off after 1 minute.
Hello MWG, Make sure that you're following the PRIMING instructions for the Keurig coffee machine. First fill completely the water reservoir and then turn on the coffee maker. Allow it to self-prime, which takes up to 4 minutes to accomplish this.
Then you place an empty cup under the dispenser and DON'T put in a K-cup into the top (yet). Now push the large cup selection and let it run. You should get some water coming out of the dispenser into the cup. After that, you should be all set to brew coffee.
If you've already tried this, unplug the machine and start over to allow the machine to properly prime and cycle through the startup process.
Since you didn't provide the model (version) of your Keurig coffee machine, I've attached a link to their site where you can get both the Quick Start Guide and the Manual for all the various models.
http://www.keurig.com/help/brewerguides.asp?mscsid=KU26EG2D0SG28L5SS3CHXW66TC75AQUB
I find it's a good idea to keep an electronic copy of all my manuals on my computer for future use and reference.
I hope you find this Very Helpful and best regards!
Posted on Dec 25, 2009
  • 28 Answers
SOURCE: my keurig will not dispense right amt of water
Try brewing a cup without a K-cup in it on the largest cup button (will brew just hot water). This will help clean it out in the event it is clogged. If that doesn't work, completely remove the K-cup holder where the needles are (careful not to get **** ) by pushing up from the bottom and rinse using hot water, preferably with a sink sprayer if you have one. Sometimes the needle can get clogged, especially if you ever use the hot cocoa K-cups, so the manufacturer recommends brewing a "blank" cup of just hot water after each hot cocoa K-cup brewed. Hope that helps...Best of luck!
Posted on Feb 07, 2010
espressonist
  • 1711 Answers
SOURCE: How do I drain water
If leave it for a couple of months without using it, later on when you will need to use it again it by 95% it will be stuck. Their many parts related with water , 2 pumps, valves, jet pasages that even one of this goggled with a sales part then the machine will need complete desaesemble manual descaled and put back together.
So I sugest to find a way so that the machine keep work atleast once a week or even lent to a friend istead of put it on the shelf for long time.
Posted on Aug 20, 2010
Keurig B31 Mini Plus Brewing System not working
There is a transformer that take the 110 voltage and reduces it to 13.8 or 14 volts depending on your unit model, it runs an electronic board or little computer in the coffee maker. It's the brains of the coffee maker. I would say you fried the transformer and possibly the electronic board if the high voltage made it past the transformer. I have replaced the transformer in our sons Keurig and that fixed his problem but he didn't plug it into 220v. The transformer is not expensive, an eBay item at around $15 or so. Taking the unit apart is not an easy thing to do. But if your handy you could figure it out and test the transformer to see it it's putting out the right voltage. Just check the voltage tag of the one that it came with so you can order the right one for your pot.
Apr 21, 2014 | Keurig B31 Mini Plus Brewing System
I live in China and brought a Keurig back with me from America. I went to plug it in a standard converter. The machine turned on for a few seconds and then shut off. I have tried turning it on again. It...
My guess is that the heater in it draws too much power for a converter. US is 110 volts, is China 220 volts? That is a step up transformer and they are not reliable.
yes 220 volts
voltage in china Google Search
Okay, a Keurig draws 1500 watts of power.
HOW MUCH POWER DOES KEURIG BREWER USE
I wonder if you bought a step DOWN transformer, 220 to 110? That would light up for a second until the heater element kicked in.
Does you look like this
Goldsource STU 2000 Step Up Down Voltage Transformer Converter AC 110 220...
or this
ELC 2000 2000 Watt Voltage Converter Transformer Step Up Down 110V 220V...
The other consideration is that the Chinese are masters of copying, so they must make a Keurig clone.
The downside is that the Chinese make rubbish electronics like your transformer.
Feb 06, 2018 | Keurig Coffee Makers & Espresso Machines
My Keurig will not turn on...no lights flashing, nothing...I used it two days ago and it was fine...i came back into work and it wouldn't do anything. I tried unplugging it and leaving it unplugged and...
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 15, 2011 | Keurig Elite B40 Coffee Maker
The Kuerig coffee maker will not start. I have checked fuses, used plugs which other appliances work well on and nothing! It was working fine yesterday
heatman101
Sep 08, 2011 | Keurig B60 Coffee Maker
My Keurig B60 won't turn on. Tried different plugs. What now?
heatman101
Sep 07, 2011 | Keurig B60 Coffee Maker
Pixma mp 240 does not recognize cl 211 and 210
Hello , i have the same problem but vice versa. i bought my printer with the 210 and 211 cartridge and i bought now the 510 and 511 and the printer wont recognize them . all i know is that my printer is specially made for canada thats why it works only with 210 and 211 , so urs must be european because 510 and 511 are the cartridges for the european version of this printer . i've tried so hard to trick the printer so accept this cartridges but its not working . did u find a solution in the mean time ? i could really use some advice
Jul 21, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Coffee Makers & Espresso Machines Logo
99 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
