Question about Viking Refrigerators
Who knows the part number of the Door gasket in a Viking VCFF136SSS3 refrigerator? thank you
  • 47 Answers
Actually you can call your local viking range distribututor or its actually a whirlpool gasket since it is sourced by them with the viking name on it.
Posted on Nov 25, 2013
2 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Hello. I have a 1988
You definitely have an air leak somewhere along the gasket. Check along the gasket for any place that is not sealed properly. It could be that you didn't quite get it in the right place as well. It might be off-centered along the edge of the door.
If you end up having to replace the gasket again with a brand new one, clean the area that the gasket will be applied, with alcohol before application.
Good Luck!
Jim
Posted on Oct 01, 2010
Viking fridge Model DDRB364RSS dripping water unto bottom cooler drawer and later under fridge - once a day or so. Door Gasket is a bit torn.
problem water in a fridge is moisture from the atmosphere--normally from opening the door but in your case from the damaged door seal
any tear regardless, compromises the compartment so have the seal replaced then see if you have a problem
Oct 26, 2016 | Viking Refrigerators
Freezer not cooling properly. Temperature alarm went off. Turned off now.
Look inside freezer on the rear wall to look to see if there is frost buildup. If yes then unplug and manually defrost defrost for about 3 hours if you only open freezer or place hot water in a bucket and place inside freezer and close the door. Let me know by answering my post here, Thanks John T.Appliance 911
Contact
click below for parts breakdown
I have a feeling the problem could be 1 of three things=> WR9X520 Defrost Timer, WR51X465 Defrost Heater or the WR50X0131Defrost Thermostat
May 28, 2015 | Viking Professional VCBB363 Bottom Freezer...
How to adjust door viking dfsb423
Viking 42" built-in units usually don't offer any door adjustments. If one of the doors are not closing well, check for obstructions blocking the door bins, worn door gasket, and possible door warp-age on the panel ready models. Viking did have top hinge recalls updating to the new "Cobra" hinge on many of their models which can be verified by calling viking and providing your full model/serial numbers. If your Fridge door is lower than the freezer door you most likely have a worn door closer located on the lower hinge of the fridge door, the closer is a 2 piece plastic interlocking/mating unit which wears down over time from friction. This usually needs to be replaced. Pleazer Appliance...
May 06, 2014 | Viking DFSB423 Side by Side Refrigerator
Condensation in the right door of my VCFF136 the gasket is teared, I don't now what caused what first?
Condensation is cause by warm air meeting cold air. I would suspect the door gasket was the cause of the condensation. When looking this up, I found many different models under this number, part number 67003547, this gasket is black in color and is a push on, means no screws required to change.
I hope this helps
Oct 15, 2013 | Viking VCFF036 Bottom Freezer French Door...
What is the part number for the oven door gasket for a Viking model number vgr36-4gd?
I searched all over and i am not finding your gasket here is a link that will help you and get you the correct part.
http://www.nationalpartscenter.com/viking/
Sorry i couldnt find the exact part number.....
Jul 02, 2011 | Viking Kitchen Ranges
One of the doors (on the Viking french door fridge) opens too wide (180 degrees). I want to tighten it so it only opens slightly more than 90 degrees. The other door is fine. Thanks.
Check with your Viking rep. I have the same problem and got word from Viking they are coming up with a new hinge doorstop at different angles. It will come in a form of a kit. The one I'm getting is about 100 degree opening. The problem I had was the door was hitting and adjacent electric oven from Viking. It just swung too wide.
Oct 29, 2010 | Viking VCFF036 Bottom Freezer French Door...
Refrigerator (VCFF136SSS3) internal temperature is over 70 degrees. The compressor does not seem to be coming on. Controls are unresponsive to lowering the temperature manually.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 04, 2010 | Viking VCFF036 Bottom Freezer French Door...
Anyone know what causes condensation on the bottom of the freezer door? seems to beed up on the gasket, but the gasket seems to seal fine. A service guy actually came out and said the gasket is not the...
There often is a heating strip that runs inside there that keeps a bit of warmth there so that condensation does not form....
The heat strip is bad ans as far as I know it is not replaceable...
heatman101
Aug 31, 2010 | Viking Designer DFSB483D
When closing the refrigerator door, the suction is minimal so the seal is not really strong in the closed door position. Consequently, condensation builds at the interior door jamb and the exterior door...
I FIND THAT ON ALL MY STUFF WINDOW, DOOR AND ANYTHING RUBBER LIKE, IT'S A GOOD IDEA TO GIVE IT A COAT OF ARMOR ALL. EVERY OTHER MONTH OR SO, IT HELPS KEEP THEM HAPPY. THERE IS ONE THING I FOUND THAT IS A LAST RESORT TO SEAL REPLACEMENT ITS CALLED ''MAGIC LUBE'' W/ TWICE THE TEFLON (HARD CORE !), NEVER USE PETROLEUM PRODUCTS (VASELINE) ON THESE GASKETS THEY **** THE OILS OUT OF THE GASKETS. BAD NEWS
YOU CAN USE A SMALL AMOUNT OF CLEAR SILICONE TO SEAL THE SEAMS WHERE THE GASKET MEETS, NND INSPECT THE GASKET FOR CRACKS IN THE BELLOWS.. SOON AS I GET HOME I'M GOING TO DO ALL OF MY GASKETS , THANKS FOR THE REMINDER. FLORIDA IS HARD ON THEM ... VOTE YES IF I WAS OF HELP.. THNX .. JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Aug 05, 2010 | Viking 36 in Designer Series Freestanding...
The right door won't stay closed
There is a recall on Viking refrigerator hinges. Check and see if your refrigerator falls under this recall. It may just require a new hinge. The recall hotline # is 888-345-2650.
You call also see if it falls in this category.
VCSB483, DDSB483, DFSB483, DTSB483 Date codes before 030104 (on serial # ). Go to this site to see if you fall under the recall.
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09242.html
Aug 25, 2008 | Viking VCSB423 Side by Side Refrigerator
Refrigerators Logo
82 people viewed this question
Top Viking Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
