Question about HOWARD BERGER-HTR IMPORT World Marketing CZQTV5M Ceiling Mounted Quartz Heater With Light
Im looking for replacement Quarts elements - HOWARD BERGER-HTR IMPORT World Marketing CZQTV5M Ceiling Mounted Quartz Heater With Light
How many quarts of oil and type does the alero take?
5 W 30 for the oil and the 2.2 Ecotec engine takes 5.8 qts and the V6 3400 takes 4.5 qts as far as the oil filter also depends on the engine. the 2.2 takes a paper element. look to the right of the engine and you'll see a black round canister with a hex looking nut attached to the top. I belive it's 32mm. use an extension but be careful putting it back on because the cap is just plastic Do not overtightnen! just snug it up firmly
May 20, 2015 | 2002 Oldsmobile Alero
What is the oil capacity of Mazda 3 2008
I have same car and i ussually put 4 liters on it when im doing change oil.
Mar 25, 2015 | 2008 Mazda 3
When I turn my CZ2011C infrared quarts heater on, it will shut off in about a minute. I took the unit apart and found a faulty two prong thermal circuit breaker located on the side panel between two quarts...
You can find replacement switches at Senasys.com. Made in the USA! It is a 430 - 1/2" Automatic reset on the shop page. More specifically and airstream mount.
Sep 08, 2013 | Comfort Zone Heating & Cooling
My taurus dumped a couple of quarts of ****** fluid out the dipstick tube on two separate occasions-whats my problem?
could have too much transmission fluid in transmission,could have cracked damaged oil filter,could have faulty or damaged incorrect pin heights to thermo element which is hot cause vent valve to close or thermo element could be bad, could have plugged drain back holes on the drive sprocket support,check color transmission fluid look transmission fluid look foamy pink looking antifreeze could be leaking into transmission through the radiator cooler.
Jan 29, 2012 | Cars & Trucks
Im about to do a ****** filter on a 2004 chevy trailblazer 2wd shallow pan, and im not sure on how many quarts of ****** fluid i will need to refill, im thinking around 5 or 6. what do you say
Most shallow pans only take 4 quarts of transmission fluid. However I would buy 5 just to make sure. Start by adding 4 quarts start your truck check your level after it warms up and add any fluid if you need to. Remember not to over fill... I hope this helps
Sep 18, 2011 | 2004 Chevrolet TrailBlazer
What oil type does my car take? its a mazda mx3
on the 1.3L 4 cyl 3.5 quarts 5W-30 1.8 L 6 cyl 3.5 quarts 5W-30
Sep 30, 2009 | 1994 Mazda MX-3
Where is the bolt to drain the transmission fluid on a honda element
Allot of trani pans have no bolt.. You would just drop the pan & fluid comes out..
Dont forget to get a new pan gaskit & a filter - if that model calls for one..
FYI; A pan drop is only part of the fluid - about 3 to 5 quarts..
The trani & torque converter hold 7 to 9 quarts all together..
Hope this helps !!
Rate me good ;o)
Jul 10, 2009 | 2008 Honda Element
Oven element replacement- Simpson eziset electric
hiya
firstly make sure the power is isolated before removing any panels.
sometimes the element will just screw out from the inside of the oven and should pull through into the oven compartment with the wires attached, simply remove the wires, replace the element and refit any panels.
hope this helps
please dnt forget to rate the helpfulness of this reply thanks kj
Nov 11, 2008 | Ovens
2006 Honda Element EXP - 40K miles
I have a 2006 Honda Element as well, and mine started making "rubbing" noises when I made a slow hard turn left or right. It had 49K on it. Took it to a dealership and had it looked at. The technician knew what it was right off the bat. The rear differential needed to be serviced. Said the fluid had broken down and needed replacing. $79.00 to fix. CRV have the same problem. Just get it serviced and it should be ok.
Jun 16, 2008 | 2006 Honda Element
Marvin Quartz heater element
Very simple to install the replacement element. Insert one end of the element into the bottom receptacle on either side, press the element down (it's spring-loaded), then slide the top of the element into the center opening of the top receptacle, push to appropriate side (the side of receptacle, same as the bottom), then release. Then do the same with the other element (if both are out).
Mar 03, 2008 | Marvin 2060 Compact Heater
HOWARD BERGER-HTR IMPORT World Marketing CZQTV5M Ceiling Mounted Quartz Heater With Light Logo
Top HOWARD BERGER-HTR IMPORT Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a HOWARD BERGER-HTR IMPORT Furniture Expert? Answer questions, earn points and help others
