Question about Sewing Machines
I have a brother ES-2000 sewing machine. My bobbin winder stopped working due to disintegrated bobbin winder tire. I just replaced the tire. When I try to wind a bobbin, it spins for a few seconds and stops with the error message "E6" which means that the motor is locked up. There is no tangled thread, or dust inside and outside. The machine is clean. I don't know what to do. Do I need to have it repaired? Please help!
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 28 Answers
You may need to take it in for repair. Try spinning your winder spindle. It is possible the spindle has seized and the motor is trying to work to hard to spin it. If it is seized you could try some natural lubricator or WD But you would need to make sure you don't spray any on any other parts other then the metal spindle itself....Hope this helps
Machine Tech
Posted on Oct 25, 2013
  • 16 Answers
SOURCE: Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Posted on Sep 27, 2008
SOURCE: machine is telling me E6 error but there is no thread tangled
I am in the middle of fixing this same error. I phoned Brother service in Manchester and they are spot on. Give them a try, they talk you through the problem and suggest things to do to narrow down the cause. Make sure you have the model and serial number as this saves time. In extreem cases you can send your machine to them by parcel post and they will look at it free of charge and then give you an estimate for any repairs needed. If you decide not to go ahead, you can elect to have the machine returned to you for the cost of the postage.
In my case I bought the machine second hand off of E-bay and was getting the dreaded tangle/needle message. I phoned the service department and I was told to thread the machine up and switch on. Then they give you several things to try. Essentially you need to get someone to press the start button while you immediately turn the handwheel forward gently and smoothly.
If this stops the message coming up then you must suspect the motor or its fuse. In my case, it would seem the machine had been dropped as there was a hairline crack in the circuit board which stopped the power getting to the motor.
Posted on Jul 30, 2009
SOURCE: Very inexperienced sewer! How do I thread it?
The way I solved this problem was to take a break! When I resumed I was more patient and found that I wasn't doing the bobbin right. I took my time and got it right this time....hooray!
Posted on Aug 25, 2009
  • 255 Answers
SOURCE: I have a Brother CS-770.
Hi. It's very likely that the needle is inserted wrong. Take the needle out and make sure that the flat shank of the needle is facing away from you (to the rear of the machine).
Try this and let me know if it helps, ok?
Robbie
Posted on Aug 13, 2010
tunde007
  • 2382 Answers
SOURCE: Brother sewing maching - model
The "E6" message means that the motor locked up because the thread is tangled.
The solution is to remove the tangled thread before continuing the operation. Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle. Then, thread the upper thread properly, and continue the operation.
Posted on Feb 10, 2011
Bobbin winder doesnt work
The bobbin winder tires on most of the new lower to medium end brother machines have a tendency to sort of melt. I honestly don't know what causes it, but basically the rubber ring that rides the handwheel and causes the bobbin winder to turn will liquify and drip off the bobbin winder and then re-solidify. It would be best to take your machine to a repair shop, to get the tire replaced and to have the old tire sludge cleaned out, though if you are adventurous, you could try it yourself. You can order a tire at the link I've provided, but most sewing machine repair shops can get you one as well.
Bobbin Winder Tire Babylock Brother X55238051
Jul 03, 2014 | Brother CS6000i Computerized Sewing...
Getting the cover off my brother cs 80. all screws have been removed and the cover comes off partially. I seems to be stuck at the turn wheel, like something is holding it fixed.
I had the same problem when opening my machine. The problem is a screw underneath the bobbin winder area. Pull the bobbin base off and then gently pull up the bobbin winder assembly from under the front cover. You will see a screw in the corner to remove so that you can complete the task. I had to purchase a service manual and then I had great success with replacing the bobbin winder "tire" (Bobbin Winder Tire, Babylock, Brother #X55238051 at sewingpartsonline.com - $3.99!!)
My bobbin winder works like a charm now. Sewing Parts Online Search
Sep 09, 2013 | Brother CS-80
Where is the location of bobbin winder tire in brother CS6000i?
The top right of the machine directly below the bobbin spindle.
Mar 10, 2013 | Brother CS6000i Computerized Sewing...
Bobbin winder belt melted
Mine stopped working too. Gave up and wound bobbins by hand for a while until I broke down and took the machine apart -- an ordeal to figure out. I found that a pliable ring on the winder was completely disintegrated (gummy plastic-like stuff). An online search found this -- a bobbin "tire" which I THINK is the part I need: http://www.sewingpartsonline.com/bobbin-winder-tire-brother-x55238051.aspx. Hope this helps. --Also cleaned all the lint out when I had the machine opened up. They don't make it EASY!
Jan 18, 2012 | Brother CS6000i Computerized Sewing...
Part for bobbin winder cs-100
http://www.sewingpartsonline.com/ has the part you need. It's called a bobbin winder "tire"
Nov 27, 2011 | Brother CS-100-T Computerized Sewing...
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Brother SE-270D sewing machine bobbin won't wind
the rubber ring on the bobbin winder has probably gone bad which would mean replacing it but you can buy a portable bobbin winder called a sidewinder for around 20.00
Jun 16, 2009 | Brother SE-270D Computerized Sewing...
Bobbin winder shaft won't spin. LCD says bobbin winding.
Jun 16, 2009 | Brother CS-8150 Computerized Sewing...
Cannot wind the bobbin
Check to make sure that the bobbin is locked onto the winder. If is not locked on then nothing will move. I know I had this problem as well and found that the bobbin must be locked on the winder.
Aug 24, 2008 | Brother CS-8150 Computerized Sewing...
Can't wind the bobbin
Bobbin will not lock on bobbin spindle, what can I do?
Mar 20, 2008 | Brother CS-8150 Computerized Sewing...
Sewing Machines Logo
154 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
