Question about Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer
Xerox 3635 communication error - Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer
Xerox 3635 mfp. Stuck on software upgrade screen. How can I reset without operator panel?
You can try to download the firmware from Xerox and rewrite through Centerware. Open up internet explorer and type in the ip address of the unit. If that doesn't work you'll need to replace the User Interface Board, the software is corrupt. The part number is 140N63294. Can be purchased at:
http://www.iteminconline.com/140n63294_140n63294-xerox-3635mfp-pwb-user-interface.htm
Mar 03, 2016 | Xerox Office Equipment & Supplies
I install xerox wc 5330 new machine when turn on gives error code 123- 333
The error is a communication error between the main board and the User Interface Board. Check the cable and reseat.
Dec 22, 2015 | Xerox Office Equipment & Supplies
09-800 on phaser 3635 xerox how to fix
That error indicates an incompatible toner cartridge for that model. Verify you are using oem Xerox toner.
Dec 21, 2015 | Xerox Phaser 3635MFP/X Multifunction...
Page pack passcode error
check in the owner's manual.
there is no way for us to know your passcode.
Aug 19, 2014 | Xerox Phaser 3635 Mfp
How do I print labels using the bypass tray on Xerox phaser 3635?
All I can add to your question is from my experience.
Make sure you have the recommended labels installed.
The fuser can cause jams when not using the correct recommended stock.
Very old labels tend to ooze a small amount of glue along the edges and can get stuck to the inside.
Print as you would do on paper, perhaps try printing on some white 80 GSM stock and hold them up to the light to check alignment.
Good luck.
Jul 02, 2014 | Xerox Phaser 3635MFP/X Multifunction...
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
Dec 20, 2012 | Xerox Phaser 3635MFP/X Multifunction...
How to reset admin password on phaser 3635
xerox machines come with default passwords.
once that password is changed only the changer knows it.
should he forget or lose the password he flat has a problem.
the reset requires a xerox laptop/tech to reset and they "will bill" you for doing it.
Jul 01, 2011 | Xerox Phaser 3635MFP/X Multifunction...
LSU error in XEROX workcentre pe220. What is the
R/sir,
I have a Fax machine of Xerox make model PE220.From BSNL line connectivity is allways out of order.I want to connect FIXED CELLUR TERMINAL (FCT).After conecting machine give dial tone for outgoing calls.and other end caller received a fax tone on their machine when they want to make a call on my machine.But printer is not printing after some LCD diplayed a massage communication error.Kindly GUIDE me for change in settings.
Thanks and regards
PK Jain
(Pennywise)
Dec 15, 2010 | Xerox WorkCentre PE220 Series
Xerox Phaser 3635MFP/X Multifunction Copier/Email/Fax/LAN Fax//Scanner Laser Printer Logo
151 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
