Question about Bionaire Dehumidifiers
Fan squeaking - Bionaire Dehumidifiers
  • 2,113 Answers
Try spraying white lithium grease all around the shaded pole motor axle while the motor is running making sure to have it get into the bearings
Posted on Oct 16, 2013
Dehumidifier squeaks when running
Disconnect it, (DO NOT REPAIR WHILE CONNECTED), remove outer plastic casing (screws), lubricate moving parts with a little WD40 or similar. Re-assemble.
If you can get to the part that's squeaking with a long tube you could try spraying silicone lubricant spray on it without disassembling.
Apr 03, 2014 | Dehumidifiers
I have a Kenmore Dehumidifier the fan will run for a while and then stops. I greased the fan motor it ran for a while and then stopped. My feeling is the fan motor bearing has loosened and as the motor...
does the motor feel extremely hot? how free are the bearings? Is there any squeaking when the fan turns? any resistance at all? If you have a problem with the bearings then change them that would cause the thermal overload to trip in the motor to unsure it doesn't burn out.
Aug 14, 2011 | Kenmore 54351 Dehumidifier
The cooling fan and will not shut off.
theres a fan/compressor relay inside the case one side operates the fan and the other the compressor,if the fan side contacts weld themselves the relay cannot cycle and the fan will not shut off,remove the wire from the relay to the fan and see if this kills the fan,but dont leave it this way as the compressor needs the fan for air circulation while operating
Feb 26, 2011 | Haier 45-Pint Dehumidifier
My 880 home dry is around 15 years old now and when on makes a loud squeaking noise, what is it and is it worth repairing , other wise works fine .regards
sounds like the fan - its worth taking apart and seeing which bit squeeks, if its the bearing try a small amount of WD40 first. try not to get any on the motor of electrics. You can by an electrolube spray if is is the Fan... Well worth taking apart, the latest EBAC models are of very poor quality.
I also had a Homedry for 15 years and the cabinets started to root first... I've had three 2560e's since all replaced under warranty - pcb failures...
Nov 28, 2010 | Ebac HD880 Dehumidifier
My dehumidifier makes squeaking noises when running. How do I stop this?
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 02, 2010 | Whirlpool AD40USL Dehumidifier
What should the humidity setting be if you are trying to pull moisture from wood floors?
Don't pull too much or the will dry, squeak, crack - not less than 50% humidity
Dec 22, 2009 | Goldstar Dehumidifiers
Fan will not come on.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
Nov 15, 2009 | LG LHD45EL Dehumidifier
Fan motor making squeaking noise; sounds like bushing failure.
PLEAS IF SOUND REALY FROM THE MOTOR SOME OF THE MOTORS HAVE BEARING CAN BE REPLACED BUT IF IS BUSHING BETTER TO CHANGE THE MOTOR.
Sep 17, 2009 | Maytag M7DH45B2A Dehumidifier
Motor runs fan does not
you may have a stripped out fan unit, the fan motor runs, but the fan does not spin? my fan was plastic and stripped out there should be a flat spot the lines up with shafton motor ifit is round your should replace fan blade unit. i could not find one so i pushed tooth picks in between shaft an fan and glued them has worked for a couple months now
Aug 19, 2009 | Kenmore Dehumidifiers
Dehumidifiers Logo
103 people viewed this question
Top Bionaire Dehumidifiers Experts
Bill Long
Gil Shultz
Michael Youngman
Michael Youngman
Are you a Bionaire Dehumidifier Expert? Answer questions, earn points and help others
