Question about OKI C Office Equipment & Supplies
OKI C330 erro 990 - C OKI Office Equipment & Supplies
How to fix 990 erro code without changing a drum ?
what model is it. that sounds like more of a hard drive issue than a drum issue.
Nov 22, 2014 | Ricoh 888073 Genuine Aficio 1035/1045 Type...
Oki c321dn 'service call 990:error'
Error 990 refers to the toner capture sensor unit, that black knob looking thing on the toner cartridge itself. I'm betting the error popped up right after changing the toner cartridge?..... therefore, it's a defective toner cartridge.
Aug 14, 2014 | Office Equipment & Supplies
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
I've unplugged it, replugged it, and still get "service call 173:fatal error"
check mechanical error on your printer by sending it to the actual technician..
Sep 01, 2011 | OKI C5500n Printer
Got filesys erroe e00100 on c330 kodak. Went and got new 1gb sd card have same problem. Kodak will not support their camera. Please help.
Is the write protection switch enabled?
Which firmware is installed in the camera?
Try an firmware upgrade. Maybe the supporting now the 2 GB memory cards.
Why download firmware version 1.07?
This firmware version improves memory card compatibility and provides general performance updates.
KODAK EASYSHARE C330 Zoom Digital Camera Firmware
Mar 17, 2009 | Kodak EasyShare C330 Digital Camera
Service call 980:Error
hola
quiem puede ayudarme a desifar el error 980 de ld oki c6100
gracias
Apr 09, 2008 | OKI Office Equipment & Supplies
51 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
