Clear spot My Clear Spot Voyager keeps powering off, even when plugged in. When I turn it back on, I see a blinking white light on the front where it says 4G. My question is why isn't my router keeping a charge, and what does this white blinking light mean?
  • 400 Answers
Perhaps the rechargable battery is bad. Do you have the manual to determine what the blinking light means... perhaps it means dead battery.
Posted on Oct 21, 2013
Paper wont feed 11x17-keeps jamming ( problem with the rollers?)
For first clear rollers w/alcool or orig clearing solvent. If it doesn't solve Your problem remove the rear cover and controll the little fingers hanging in the way of sheet edge. Some of them may be in wrong position because of missing or released spiral. Fix it back with a medical clip or you may remove the whole finger (one piece) if You don't find the spiral. Control and clean the turning surface.
You need strong light in the spot because of the usally black accessories.
Don't miss monthly cleaning procedure.
May 15, 2012 | Canon ImageRUNNER 3235i Black and White...
Had a power outage for several hours. Power came back on but the printer came on with all lights blinking. Turned power off and back on but the same problem. What's happened, and what do I do?
Nearly all later printers have circuits that stay 'alive' even with the power turned off. Try pulling the AC plug overnight' this should clear most stored errors that may still be present.
Jan 01, 2011 | Brother HL 5250DN Laser Printer
Dc3535 does not start it keeps blinking at 1st spot
trying to
press Power saver + Cancel all + 6 at the time of power on
it clear all pending jobs
and then again try to power on
other wise it can be checked by PWS aoftware if you have
Oct 03, 2010 | Xerox DocuColor 3535 Copier
Why spot in the copy? ir 400 canon
If its black spots on the copy it could be that your drum unit needs to be serviced or change. IF it's white spots it could be a problem with moisture in the paper. IF it is moisture doing a copy on the back side of the paper should come out clear.
Jan 21, 2010 | Canon imageRUNNER 400S Copier
New front loading Kenmore The drain hose is too powerful and the water keeps shooting back out of the drain. Drain is perfectly clear. This is the 3rd washer in the same spot. Is there some sort of an...
drain is not clear enough you DO NOT want your new washing machine to be constipated.lol... It has to drain the water out at its speed or you will develop other problems if you try to restrict it..
Jul 05, 2009 | Kenmore Washing Machines
Blue light flash cartrige bangs one end to other then light flashes still, all clear have cheaked
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
May 23, 2009 | Lexmark X2350 All-In-One InkJet Printer
All the lights on my HP 1350 printer are blinking and it will not print. Normally where you could put the number of copies i " E" is in thaat spot.
In addition to providing information about current tasks, the lights on the front panel can also indicate error conditions, as described in the table below:
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HPPSC.
2 Turn your HPPSC off and on by disconnecting the power cord and reconnecting.
Alternatively,
All ights blinking: An error caused the HPPSC to stop functioning.
1 Turn the HPPSC off and then on.
2 Restart your computer.
3 If the problem is not corrected, unplug the HPPSC and plug it in
again.
If the problem persists, contact HP.
Apr 26, 2009 | Office Equipment & Supplies
High pitch buzzing.
Hi there
Let's make ur problem a bit clear. "white lines" how? where?
meaning retrace lines with full raster or a single vertical line?
buzzing sound? without even turning the power switch of the TV to "ON" or when u just plug the power cord?
I'll check for schema, mean while can u tell me where the resistor leads to? is it a fusible resistor? if so , to which area the resistor suppliers power?
Regards
Rifaa
Nov 12, 2008 | Zenith C27A24T 27" TV
Screen in toast!
That is definately a cracked lcd your describing! I doubt there is an easy solution but maybe... If you are able to get into the menu and disable the LCD that might help. However! The fact that the LCD is broken shouldn't keep the camera from running (though its remotely possible) If you can't shut it off or work without it the odds are you've got an expensive paperweight. At least thats what I gather based on your description.
Aug 27, 2007 | Fuji FinePix F470 Digital Camera
White spots
In addition, flash lighting dust doesn't make a white spot, but a fuzzy whitish circle (out of focus). The image underneath is still visible, but distorted. These are definitely not flash reflecting on dust.
Sep 07, 2005 | Panasonic Lumix DMC-FZ5 Digital Camera
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
