Question about Curtis LCD3227A 32-inch LCD TV
My curtis tv model LCD3227 the picture goes in and out 5 mins after i turn it on the sound u can hear and the power stays on
3 Suggested Answers
vinceisaac
  • 2432 Answers
SOURCE: Curtis 42 inch Tv Sound fades in and out
audio amplifier section problem.check for bad amplifier ic.
Posted on Aug 17, 2012
gopakumarg43
  • 74666 Answers
SOURCE: I have a Curtis LCD2425A flat screen tv it powers on fine with picture and sound. After about 20 minutes the screen goes black but the sound works fine. If you turn the set off and then back on the Cu
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Posted on Jan 12, 2015
I have a Curtis lcd3227-A and have a one for all remote need codes
Use the code search feature of your One For All universal remote to find something that will control some or all functions of your Curtis lcd3227-A. If a search through all codes stored in the remote fails, you may have to try another universal remote. All universal remotes do not store all possible codes.
May 17, 2016 | One For All Televison & Video
Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Oct 26, 2008 | Vizio Televison & Video
I have a Curtis LCD2425A flat screen tv it powers on fine with picture and sound. After about 20 minutes the screen goes black but the sound works fine. If you turn the set off and then back on the Curtis...
Jan 11, 2015 | Curtis LCD2425A TV
TV turns on, hear sound but no picture. Bulb isn't coming on. TV goes off after about 2-3 minutes. Bulb was just replaced 5 months ago.
Need the model number of the set and also if any lights on the TV come on or blink when the picture goes out or not.
Feb 09, 2013 | Televison & Video
I turn my tv on the picture and sound all work and after about 20min the picture goes to a black screen and I still have my sound. I turned the tv off wait about 5 min turn it back on the picture come on...
If you have electronics experience - check the power supply and make sure you are getting the correct voltage to your inverter boards and main av board - also do you see any movement on the screen take a flashlight and shine on the screen - if you can see a dark image on the screen check inverter boards and power first.
thanks,
michael
Mar 21, 2011 | Element Electronics FLX3210 32 in. LCD TV
I have a GE 52 inch projection screen TV. I have replaced three CP's: 150, 114, 120. I also replaced the flyback. The TV worked only a couple of times. I turned it on, then off, and right back on. I only...
You can start with resolder deflection board around Hori output, coils and Big diodes also make sure 2 ribbon connectors are pushed in correctly and in good CK Both Ribbons .
Mar 24, 2010 | GE D52GW12 52" Rear Projection HDTV-Ready...
32in. rca lcd tv GOES BLACK
this is the conversion IC chip , it needs to be replaced
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
OVERHEATED?
yes open it up get dust out run small fans in nit see how long it stays on
Sep 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
Sound bar only goes to #5 (low sound)
It maybe a model that is used in hotels and has a volume lock on it.You need to contact the manufacturer, or read the instructions on how to override it.
Jul 11, 2008 | Philips TP2784C TV
Curtis LCD3227A 32-inch LCD TV Logo
35 people viewed this question
Top Curtis Televison & Video Experts
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
