Question about DSC Ws4945 Wireless Door Window Contacts 4
Door contact sounds many times a day without the door being opened or jarred.
Hi all,hyundai get some times power window doesn't roll back when I open door panel then It roll up for a while it does roll down but don't roll up any way to fix this
Sounds like a power window motor. Sometimes this will help diagnose your problem for the mechanically uninclined. While holding the switch to power the window while the window is stuck, just bank on the inside of the door panel for that window without causing damage. Sometimes this will jar the motor and it will start to move. This is a sign of a bad power window motor. It may also be a switch as the alternative problem but most likely the power window motor. I recommend replacing the window motor and window regulator at the same time. You can usually buy both together.
Mar 16, 2016 | Cars & Trucks
The freezer door will not open. it feels locked
There is no lock on that door and the only latch is a magnetic gasket around the door edge. It sound like one of your frozen packages make have shifted and is causing the door to stick by hitting the package. Just guessing on this one but maybe if you can bounce or jar the refrigerator somewhat the package may move enough to open the door.
Mar 05, 2015 | GE Profile Stainless Bottom-Freezer...
Drive door won't open from outside on 95 ford thunderbird
if your door is unlocked and it wont open from outside the handle to door latch rod has come undone sometimes the clips holding on handle become brittle or some models the rod uses gravity to sit in the latch and can be jarred out.
take door pad off and its all self explainatory or go to body shop they do these 20 times a day and usally wont charge much
Jan 28, 2014 | Cars & Trucks
Hi i have Cherokee sport 2001 and central door locks not working, at the same time all passenger windows cannot be open only i can open from driver side console. few days back all the door locks start
Try unplugging the passenger door module from the wiring harness. Module may be bad. I see one screw holding it with tabs at the other end. You should be able to pull it up without removing the door panel. I see there are modules online for less than $40.
Nov 04, 2017 | 2001 Jeep Cherokee
I have borrowed an old rca vhs camcorder inhopes of converting 4 vhs tapes to dvd. I have a Pinnacle systems DVC 90 to plug from RCA to Computer. I cannot get to cam to open? I charged the battery but...
It sounds like one of my older, been-in-storage for awhile, camcorders. When they sit for without being used fairly regularly, there is often a bit of dampness that settles into the camera. If left in a warm room, this may help dry it up and allow the open/eject function to work. To help it get un-stuck, you could gently press inward on the door (do not pry outward) and try to loosen it up. It may take a few times with this process to allow the door to jar loose.
May 15, 2011 | RCA CC-439 Camcorder
My door ajar light will not turn off and i cant find the door things or what door it is how do i know or can i check ..... and if it is my trunk how do i ajust it.... it is a 99 ford expedition
in most cases the a jar switch is stuck, spray some wd40 at the upper part of the latch on the drivers door ( the door used the most ) and open and close the door several times, the wait for the a jar light to go out, this happens all the time at my shop. hope this helps.
May 12, 2010 | 1999 Ford Expedition
Freezer whistles after closing door; new sound after a freon rech
yes sir,your unit is working well right now, at this stage, freezer section is already at the peak of its performance, it creates suction motion as you close the door (frzr). with this, sometimes you can hear whistling sound or most of the time.it is only a sign that the cooling system is working well.as the temperature goes down it happens, to see it, watch the gasket how it behaves during that moment sir.there is a suction sound.blower is also in suction motion because it diverts airflow going to ref section thus creating this behaviour on the gasket and the door as a whole, dont worry sir that is normal, or try to clean the tip of the gasket to reduce the slipping sound.
Mar 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The dash light indicates I have a door opened and a chime dings when I hit a bump. All the doors are closed.
Check the 2 contacts on the passenger sliding door. If the door is out of adjustment they will have poor contact and a bump will jar it and turn on the light and chime. Make sure the side door closes securely.
Jan 28, 2010 | Dodge Grand Caravan Cars & Trucks
DSC Ws4945 Wireless Door Window Contacts 4 Logo
23 people viewed this question
Top DSC Home Security Experts
Steve
don1956
Level 1 Expert
Tom Chichester
Are you a DSC Home Security Expert? Answer questions, earn points and help others
