Question about GE Ovens
F1/7 error on GE profile electric stove model JBP90WS1WW
5 Suggested Answers
SOURCE: replacing glass top on stove
I also have a ge spectra with a broken glass.
Posted on Jun 26, 2008
SOURCE: error code
found sensor inside oven no continuity am ordering new sensor should fix problem
Posted on Jan 10, 2009
fixyourboard
  • 310 Answers
SOURCE: GE Profile Stove baking option not working
Possibly the bake igniter, the temperature sensor or the electronic oven clock/control. Does broil mode heat properly or does it run cool also? If broil heats to the proper temperature then the temperature sensor is probably ok. That leaves the ignitor or the controller which takes some more troubleshooting. If it is the controller, we repair them at www.fixyourboard.com.
Posted on Aug 31, 2009
  • 668 Answers
SOURCE: F7 Error
The F7 error code on your oven indicates the touch pad has failed. To repair it, you will need to replace the touch pad which is listed as a control panel.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that holds the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touch pad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
Hope this helps.
Thanks for using Fixya.
Posted on Dec 15, 2009
How to remove the touchpad on ge profile stove, I have f7 code
On most GE ovens you open the door and across the bottom of the control panel there are 3 1/4 inch screws, one in the center and 2 on either end going straight up into the console. remove the screws and slide the control panel up then out to you. Thats how you do it.
Aug 28, 2011 | GE Profile JTP18 Electric Single Oven
How do you get the ge profile oven time set to not on military time. we push clock time and the time, and it defaults to military time.
I don't know this particular model but on a lot of different brand stoves/ovens the clocks only work on military time. I have encountered many of these and they are manufactured to work on this time only. Unfortunately I have one sitting in my kitchen!
Mar 13, 2011 | GE Profile JTP56 Electric Double Oven
Ge stove flashes f2 and beeps
F2 is a oven sensor error . remove and or replace the oven sensor if doesn't stop replace oven control
Mar 31, 2009 | GE Profile JTP18 Electric Single Oven
Glass Top Stove
Thak you, I decided to call a Service Tech from Sears who came and fixed it. Thanks
Sep 24, 2008 | GE Profile JTP18 Electric Single Oven
GE Profile Performance Double Oven
I was getting only the F0 error code. The wiring diagram inside the stove said F0 indicated a bad off button on the keypanel. There were instructions to check the ribbon cable on certain lines, with values for the resistance. It seemed to check out, so I ordered a replacement and voila, it worked.
Jun 11, 2008 | GE Profile JTP56 Electric Double Oven
Replacing glass top on stove
Jan 14, 2008 | GE Profile JTP18 Electric Single Oven
GE glasstop stove problem
Try removeing power too unit for a couple minutes. You can due this by turning off breaker. Sometimes this will reset board. If not, you may need an ERC board.
Nov 04, 2007 | GE Profile JTP18 Electric Single Oven
Oven won't stay hot
http://www.lieffcabraser.com/profileovencomplaints.htm
the digital control for the JPT-18 and customer are trying to have GE replace them. It is called the F7 error
Click the link above to see more about the problem. GE wants the customer to pay for the error. Hope this helps. JT
Oct 23, 2007 | GE Profile JTP18 Electric Single Oven
Ge oven problem
Look for a microswitch connected to the lock mechanism at the back of the stove. The switch is probably broken.
Jun 07, 2007 | GE Profile JTP56 Electric Double Oven
Ovens Logo
61 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
