Question about iRobot Roomba 560 Robotic Vacuum
Roomba 550 stops after 30 seconds of operating. Battery was replaced 1 yr ago to the date. Also makes screeching noise. Did clean the gear box in 1/13 but didn't put lube on gears.
  • Julie Jennison
    Julie Jennison Oct 17, 2013
    Battery did need to be replaced. I have cleaned all the brushed (including axel under yellow brush caps) & cleaned out the gear box. The screeching noise decreases after the first 30 seconds the Roomba runs
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 47 Answers
OK, then maybe you should diassemble the machine and put some lubrication on the gears. Make sure everything is in it's correct place when re-assembly. Make siure the fan blade that creates the suction isn't damaged or even cracked. If it is, replace it. If it's stopping shortly after starting, it may have something OUT OF PLACE, that's causing to much friction.
Posted on Oct 19, 2013
otacon
  • 1944 Answers
SOURCE: IRobot will stop after few seconds ..
How old is the unit? It looks like the battery needs to be replaced.
Posted on Feb 24, 2008
SOURCE: My roomba 560 has brushes that spin one rotation
Here's the solution to this problem...
Remove the rollers and run the Roomba and see if the problem goes away. If so, here is the solution to the problem...
Each roller has a little yellow cap on one end. Pull this cap off (it should come off easily) and remove the crud that is wrapped around the "axle" of the rollers. The crud keeps the cap from going far enough down on the axle, essentially making the roller longer. This causes the roller to get into a bind and results in the roll-thump-roll-thump-roll problem. Once the crud is removed, replace the cap, replace the roller (notice how it drops in easier now?), and enjoy your Roomba again.
Posted on Apr 25, 2009
  • 87 Answers
SOURCE: Roomba 4100 lights up when I hit the power and dies
Most likely it is a worn out battery. You can buy a new one for about $70 at iRobot.com or read their help section.
Posted on Jul 05, 2009
Milleniumboy
  • 106 Answers
SOURCE: my roomba 550 keeps making a clicking noise and it
Hello, this type of Clicking sound is most likely a loose alignment within the brush axles. There is a particular way the brushes have to go, each in an individual position. Try to tinker around with the position(s), :) lol... this should solve the Clicking caused by miss ~ alignment. :)
Ciao
Posted on Jan 29, 2010
  • 27 Answers
SOURCE: my roomba 550 makes loud clicking noises and stops
pull brush rollers out.pull funny lookin yellow ends off and clean hair ect.out .also pop out front wheel and clean
Posted on Aug 06, 2010
Roomba 530 is clicking when running then stops
The battery is not charging and has died a noble death. Buy a new battery.
Nov 28, 2013 | iRobot Roomba 530 Robotic Vacuum
My Roomba 560 just goes in circles and then stops and beeps. ! red is on but will not tell me what the problem is. 2 months ago it was making a clunking noise and would say that I needed to remove and...
Your bump sensors are malfunctioning. The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great. I'd recommend them...
Aug 02, 2011 | iRobot Roomba 560 Robotic Vacuum
Telling to clean bruses and clicking noise
Hello Sara
if its under warranty, call iRobot, they will probably replace the cleaning head.
If not, you'll need to open and clean the gear box.
there are few manuals with images on how to do that here is one
Have fun and enjoy your Roomba
Avi
Apr 13, 2010 | iRobot Roomba 530 Robotic Vacuum
My roomba 550 keeps making a clicking noise and it says to clean the brushes, even after I do it
Ciao
Jan 29, 2010 | iRobot Roomba 550 Vacuum
Roomba cuts off after a minute or so.
If you have a 400 series Roomba, try removing the battery, then holding down the power button for ten seconds, then recharging the unit before you run it again.
If you have a 500 series Roomba, don't take out the battery-- just press and hold the "spot" and "dock" buttons for about fifteen seconds. The Roomba will play a tune, and you can then charge it and try running it again later.
May 13, 2009 | iRobot 4150 Roomba Vacuum
Roomba stops running after 2 minutes
First drain the battery completely and then take out battery and charger and hold power button for 30 seconds and then clean the roomba with compressed air take out all compartments and blow air thoroughly everywhere especially near the wheels where the wheel sensors are. Leave battery to charge for full day and try to run.
Jan 31, 2009 | Roomba Robotic Floor Bagless Vacuum
iRobot Roomba 560 Robotic Vacuum Logo
79 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
