Question about LG 50PC3D 50 in. Plasma Television
Error codes table - LG 50PC3D 50 in. Plasma Television
    Top Expert:
  • LG Master
  • 73,698 Answers
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 16, 2013
Error code 91.03 on a trane tzone 950ac52za
Turn breaker off to air handler for 10 seconds, then back on. Give time to initialize and see if error clears. If not go into technician access to diagnostics. I believe in there you will find summary table. SUMMARY TABLE is what you need. Whatever is "offline" is the problem. Delete that item and go from there.
Dec 19, 2016 | Heating & Cooling
What is failt code 16988
If this is code 16988/P0604, it refers to Internal Contr.Module Random Access Memory (RAM) Error. This seems to relate to the ECU and may reset if the car is left without power for a while (disconnect the battery). Or it was triggered after the ECU lost power.
If it doesn't disappear, the fault codes should be reset with a VAG-COM tester. If it persists, it needs further diagnostics at the dealer.
Here's a table of VAG fault codes:
Audi Online Technical Library Diagnostic Trouble Codes DTC Tables
Here's another useful resource at ross-tech:
Main Page
Just type your error code into the search box and read on :)
Aug 03, 2014 | Skoda Octavia Cars & Trucks
I have fz1 2008 and engine error code 39 and 34 how i fix it? Any help please jeff_thy@yahoo.com
This link has a table of FZ1 error codes: Thread ECU Error Codes Table
Code 34 means Faulty Ignition - "Fuel is cut off to the cylinder in which the error was detected"
I wasn't able to find the code for 39.
May 17, 2014 | 2008 Yamaha FZ1
Error code rs1
help me unlock soon CA3
Jul 01, 2013 | Zynga Texas HoldEm Poker
Zynga poker error code RS1
i have 11 m when i click 100k/200k/200k/400k table show up this message cold not join room:you are not authorized to enter the room.error code:RS1. i can play only 80 k down tables HELP ???
Jan 12, 2012 | Zynga Texas HoldEm Poker
Error code rs1 zygna poker Problem
the poker send me a mesage.[error code RS1] what kain i do for this because i can not play a big table whith my friends. i hope to help me soon ty.
Sep 02, 2011 | Watches
The TV will not power on and the red light blinks 6 times.
This is a basic blinking error code table:--
Error Code Table
0 = No error
1 = X-ray protection, E/W protection, and/or Vertical protection active
2 = High beam current protection active
3 = Reserved
4 = +5V protection active
5 = Signal Processor (IC 7150) register corrupted
6 = Signal Processor (IC 7150) error
7 = Total failure
8 = Internal RAM error (Microprocessor IC 7000)
10 = NV memory (IC7088) addressing error
11 = NV memory (IC7088) size error
12 = Histogram (YUV) (IC 7770) error
14 = Sound processor I²C error (TDA9855)
16 = Main Tuner I²C error (IC 1125)
17 = PIP Processor I²C error (IC 7350)
18 = PIP Tuner I²C error (IC 1127)
But in most cases the power cord is "defective" as it's a common issue.try with new cable 1st or else follow the chart and replace the part as per coding chart on main board.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 28, 2010 | Panasonic TH-42PX60U Television
42PFL5332D/37 does not turn on red light flashes 6 times.
Don't have a "solution" yet, but found this table that decodes the blinks:
Error Code Table
0 = No error
3 = Reserved
7 = Total failure
I, too, have the 6 blinks of a red light. I found another person online that suggested that perhaps the power cord was "defective" as it's a common issue. I replaced the power cord with one from an old computer (they're the same cord) and it seems to be OK now. That's all I can offer you at this time.
Jan 20, 2010 | Philips 42PF7320A 42 in. Plasma HDTV
Nvidia geforce 8400 GS pci code 12 error not enough free resources to use (no conflicts)
Error code 12 is one of those errors I hope you won't ever receive, because fixing the problem can be rather difficult. There are two different things that can trigger this error. The most common problem is a resource conflict. Essentially, this means that two hardware devices have been assigned overlapping resources.
A corrupt Multiprocessor System (MPS) table can also cause error code 12. If the MPS table is corrupt, it can cause the BIOS to allocate insufficient resources to hardware devices. I have had a really tough time locating information regarding a solution to this problem. From what I have been able to tell, though, it appears that an MPS table can become corrupt as a result of a damaged hardware abstraction layer (HAL). If that is the case, then reinstalling Windows may fix the problem.
In plain English :D either you have 2 pieces of hardware trying to use the same resources (unlikely), or you have software that is trying to run the same driver twice. I believe that about the only way you are going to get rid of that message is with a clean install. Even then I wouldn't guarantee it.
Jul 17, 2009 | Evga NVIDIA GeForce 8400GS, PCI Express...
Error reading patition table (MBR)
well am not 100 pct sure but i Guess u need to restore ur mbr /track 0 sector 1
Ntsnpr@yahoo.com
Sep 16, 2008 | Seagate HDD 40GB 7200RPM ATA100 2MB...
LG 50PC3D 50 in. Plasma Television Logo
29 people viewed this question
Computer Repairing
Computer Repairing
