Question about U-Line Icemaker
Cleaner for uline CLR2060B - U-Line Icemaker
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
Feb 21, 2010 | U-Line Uline Origins Series...
My uline suddenly stopped making ice. the cubes are very thin although i adjusted the knob to the maximum thickness. Sometimes it works for a day or two then stops again
You should never have to adjust it to the highest setting. You could have a sensor problem or a sealed system problem Or you could of used the wrong cleaner and now the ice isnt sticking on the grid. You can only use the u-line cleaner.
Sep 23, 2009 | U-Line Icemaker
Wiring came unplugged need wiring scematic for uline ice maker
wiring diagram is on the back of the machine. If you have clear ice maker it may be on the back of the front plate.
Jun 01, 2009 | U-Line Uline Origins Series...
The door to my under the counter uline frig/icemaker doesnt shut good..It wont stay on the bottom hinge..
The hole on the bottom of the door might be cracked. What model is it? you might need a bushing for the door.
Mar 30, 2009 | U-Line Uline Origins Series...
Uline Icemaker has dammaged gasket door
no, you will need to replace the gasket. U-line gasket is easy to install. You can visit their website and under customer service you will see parts locator. The gasket just pulls out of the track and the new one pushes back in the track. www.u-line.com
Mar 18, 2009 | U-Line Uline Origins Series...
My uline drawer fridge quit working. Who should I call to fix it?
I would call Uline directly and allow them to recommend someone in your area that does warranty work for Uline. In this fashion, you are assured professional results and OEM parts....
Good Luck, Eric Campion
Feb 26, 2009 | U-Line 75R Refrigerator
Uline ice maker not cool enough to make/keep ice
one of two things
1. fan under unit stopped up or quit
2. small freon leak usually in freeze plate
Nov 04, 2008 | U-Line Icemaker
U-Line Icemaker Logo
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
