Question about GE Ovens
GE double oven JK950 starter button on top oven won't depress. Other setting buttons and readout OK
SOURCE: GE double oven - bottem will not heat, top oven fine
I had a similar problem. Solved mine by resetting the manual reset thermal switch. The switch for the top oven is located behind the control panal which can be removed easily by taking out three screws then lifting up an leaning out. The switch has a red reset button, just push it in till it clicks.
For safety, SWITCH THE BREAKER OFF WHILE YOU DO THIS!!!
The lower oven switch is located behind the vent grill between the two ovens.
GE should be ashamed of hiding this feature-it isn't mentioned in the manual. I discovered it on a schematic hidden behind the control panal.
Good Luck, DVS1936
Posted on Nov 02, 2008
Sea Breeze
  • 4654 Answers
SOURCE: GE Profile JT952 Touch Pad Button Issue
Try this link
http://www.fixya.com/howto/h155060-dreaded_f7_error
Posted on Mar 28, 2009
  • 6 Answers
SOURCE: KitchenAid Superba double oven: can't set clock.
If you turn the center knob (marked 'time') to the right, it sets the timer; but if you turn it sufficiently far to the left, it goes into clock set mode. When you get to the correct time, press start.
Posted on Jun 30, 2009
SOURCE: tricity bendix double oven
My oven's fan is working but no heat what so ever what shall i do
Posted on Jul 24, 2009
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    Ge profile performance double oven. getting an F7
    F7 is a stuck keypad/button.
    Push all buttons at random several times each. This will sometimes un-stick a stuck button.
    If that does not work the keypad control will have to be replaced.
    Jan 16, 2010 | GE Ovens
    Cant reset the clock
    Press the cook time & ready time buttons simultaneously and keep the buttons depressed. use the plus and minus buttons to set the time of day. A (Auto) symbol goes out, cookpot symbol comes on.
    Jan 06, 2010 | Tecnik TKC8522 Electric Double Oven
    GE JTP56 double oven controls OK top OK bottom no heat
    have you inserted the business card as described in the solutions?
    Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
    Try this link
    Mar 28, 2009 | GE Profile JT952 Electric Double Oven
    I need the instructions for a diplomatic double fan oven as the second oven is set on auto timer and I can't get it to work.
    i had the same prob..... manual operation, to set the programmer to manual (cancelling any auto setting),press the cook time and ready time buttons simultaneously.
    To set time of day, press the cook time and ready time buttons simultaneously and keep the buttons depressed. Use the plus and miuns buttons to the the time. A(auto symbol goes out cookpot symbol comes on.
    Mar 27, 2009 | Ovens
    TOp Oven Light ..
    if its a brand new unit (still in waranty) make the service call
    Aug 30, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
    GE Profile -Installed wall oven - won't heat
    brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
    Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
    Ovens Logo
    24 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Are you a GE Oven Expert? Answer questions, earn points and help others
