Question about Homelite Mighty Lite Lawn Trimmer
What is the ratio of oil/gas for trimmer
I have a gas trimmer and need to know what the ratio 'of what' that needs to go into the container to make it work - like the oil and gas
  • susan688 Apr 24, 2009
    I'm a ma'am - thank you very much.
  • 6 Answers
SOURCE: Correct gas to oil ratio for Homelite Mighty String Trimmer Model
most trimmers are 50:1. or 40:1. i would use synthetic 2 cycle oil and use the 50:1 ratio. i know guys with trimmers that require 50:1, and they use synthetic at 80:1 with no problems for years. they say the engine runs cleaner. i am a part-time lawn care operator.
Posted on Jun 19, 2009
SOURCE: 25cc trimmer gas ratio mixture
the correct ratio is 50-1 mix
Posted on Jul 01, 2009
  • 23 Answers
SOURCE: What oil/ gas ratio is needed for a ST185 Homelite
32:1 should work fine
Posted on Jul 08, 2009
  • 468 Answers
SOURCE: GAS TO OIL RATIO
Homelite products are 40:1 gas to oil ratio
Posted on May 28, 2010
Testimonial: "QUICK & PRECISE!! A GREAT HELP, & GOOD WAY TO FIND ANSWERS."
miket756
  • 2702 Answers
SOURCE: What is the oil to gas ratio for a Homelite ST-155
40 to 1,,,40 parts petrol to 1 part oil,,,,1/2 oz oil to 1 pint or petrol
but iv all ways ran mine on 30 to 1 ok,,it smokes a little,,but if its smoking there is oil getting to the piston and bearings,,,so the engine will live a lot longer,,,my pall runs his on 20 to 1??? now that smokes!
but he's run it on this for 25 plus years??? and he gun's it to death,,
so il say no more!
Posted on Jun 13, 2010
Oil to fuel ratio
Many of the 2 cycle motors use a 40:1 gas to oil mix. There should be a label on the motor that tells what the mixture should be. You also can buy a premixed container that has the gas ad oil mix all in one can. Just pour it in the gas tank, then pull the starter cord.
Mar 17, 2014 | Garden
Need to know the gas ratio mixture for a Echo Gas Trimmer GT2400 [serial#004349]
hello sir, the gas / oil ratio is, 3/4 o/z per quart or 2.6 o/z per gallon of two cycle oil, any two cycle oil will do,this is how i mix mine and never had a problem,it is a good mix.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you. ~~
Feb 18, 2012 | Echo Garden
I have a Ryobi Ry30522 weed whacker that i need to mix gas/oil for and I don't know the correct gas to oil ratio. The two cycle oil container has lots of different ratios ranging from 16:1 up to 100:1 and...
some of these machines are 40:1 and some are 50:1 please check your owners manual,or ask the shop where you bought it,be very careful as the incorrect mixture can damage the machine,rgds
Sep 25, 2010 | Ryobi Garden
Homelite gas trimmer ut20602 from 1998 need oil mix ratio...is it 40:1 or 50:1
Use the 50:1 ratio oil mix.the oil bottle will tell you how much oil that you will need to mix with how much gas you have,40:1 will make the trimmer smoke too much and it will foul plugs prematurely but won't hurt the machine.
Jul 30, 2010 | Homelite Mighty Lite Lawn Trimmer
Need ratio for craftsman gas line trimmer
i think the mixture is 50:1 50 petrol and 1 oil
Jul 21, 2010 | Craftsman 25cc Gas Line Trimmer
Toro proline model 53030 how do you install line and what size line? also what gas do i use ? thnks
they are usually .60 or .80. mm line size. You use any gasoline that is FRESH ONLY! I can not over stress how many problems that saves you over time. But for that model (and many like it) you must understand its a 2 cycle engine (or 2 stroke) now this is VERY IMPORTANT. Gasoline alone in any 2 stroke engine will destroy it if used alone, without mixing special "2 cycle or 2 stroke" oil with it. Look at the gas cap, or a sticker or a label on the trimmer and you will see a 2 cycle oil to gasoline ratio indication number. That means what it implies, and yes, you mix the two together. Common mix ratios are typically 30:1 (30 parts gas to 1 part oil) Some vary up to 50:1 some as low as 25:1. If its not on the trimmer try the owners manual ITS THERE! generally that means a 2.5 ounce bottle of 2 cycle oil (Not Car Motor oil! There is a big difference in performance for 2 cycle motors. You need to mix 2 cycle oil types only) poured into a 1 gallon container of gas. Shake it up, fill your trimmer with that. Here look at this link. http://www.youtube.com/watch?v=SuGfDNH6fXk&feature=related (Copy and paste it into your browser'd address bar, then hit enter.) They will show you all you need to know on how to restring the line.
May 09, 2010 | Craftsman 25cc Gas Line Trimmer
What is the correct ratio gas to oil for my stihl fs 66 trimmer
Use a quality 2 cycle oil and mix it to the oil manufacturer's recommended ratio. Today it is usually 50:1.
Fuel in the USA contains ethanol; try to use up your mix in a month or less. HTH
Lou
Jul 28, 2009 | Garden
Jun 18, 2009 | Homelite Mighty Lite Lawn Trimmer
Gas mix
ok buy the cheap gasit does not need the high price stuff 1 gallon of gas and 1 small bottle of two cycle oil. thats all you need
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
345 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
