Question about VideoLogic Sirocco Crossfire
Speaker output dont seem to get output from two of the ports, how do i fix this problem?
  • 95 Answers
I assume you mean that you can't get sound from the rear and sub/center jacks on your computer. Check to see if you have some sort of audio management program preinstallled from your computer's manufacturer in Control Panel, such as Realtek HD Audio Manager. It should have options for changing what each output does.
Posted on Oct 16, 2013
I don't know which port in the back of the Pavilion to connect the black wire from the speakers (that connect to the right speaker with red and white ends). Any ideas? They are labeled as side, rear...
To get "surround" sound, when you face the computer, you will have:
* 2 front speakers, one immediately on each side of the computer
* 2 side speakers, one on each side of your head
* 2 rear speakers, one behind each side of your head
Thus, when the sound is of a jet-plane coming towards your face,
you'll first hear the sound in the front speakers,
then in the side speakers,
and finally in the rear speakers,
to produce a sound-effect of the jet passing over your head, and going "behind" you.
Usually, for "front" speakers, one speaker connects to the other speaker, and the second speaker connects to the "FRONT-audio-output" connector on your sound-card.
For side speakers, one speaker will connect to the LEFT-side-audio-output port,
and one speaker will connect to the RIGHT-side-audio-output port.
For rear speakers, one speaker will connect to the LEFT-rear-audio-output port,
and one speaker will connect to the RIGHT-rear-audio-output port.
Jun 01, 2011 | Audio Players & Recorders
I have xpod speaker i dont no wich lade is audio input and output
u have not described ur problem completely....i.e. the model or name of xpod speaker. and a speaker has only one lead and that is for output.however , if u have more than one leads that may be for microphone. the microphone lead end is pink (in some cases) and the speaker lead is green and it is the same colr for mic and speaker at the back of computer. simply play any media file in any media player and plug any of the lead in the green port at the back side of system unit(cpu).(if voice comes insert the other lead in pink port).otherwise insert the other lead in the green port and speaker will work
May 04, 2011 | Computers & Internet
Connecting to ports?
Generally the input/output jacks on computers are color coded and the green is for speak output. If you still don't get sound, verify you have working sound card drives installed in your OS and that the volume isn't muted.
Jun 09, 2010 | HP JBL Platinum Computer Speakers
New pair of La Cie speakers. Dell pc. Not sure whee o plug in varous leads, but it now does the beefs etc on Windows. But when I put a CD in there is no sound at all
I think you were disconnected from our conversation. Anyway, the LaCie speaker is USB powered so you dont have to plug it into a power source because they will be powered by the USB port. You dont need to plug them into a speaker output on the computer as well. Just plug the USB cable of the speaker into your computer's usb port. As for the other speaker, there is a cord that used to connect the speakers together. Just plug it underneath the first speaker, that says "speaker" source. Then go to your Control panel >> Multimedia >> Audio and choose them as your Audio Output device.
Mar 04, 2010 | Computers & Internet
I have no sound from one of the speakers on my Z-2300 . The speaker itself isn't the problem. I swithced the wires on the back of he sub woofer and both speakers worked when I plugged them into the left...
probably not, seems the output ic or transisters are blown in the right channel. take it to a service shop. also see if under warranty, if you bought it new within the past year. it will be fixed or replaced..good luck...
Nov 13, 2009 | Logitech Z-5500 Computer Speakers
I am trying to hook up a powered sub woofer to a yamaha rx-v461 and i dont know what cables go where on the back of the sub there are two speaker ports and there are two plug ins but each speaker port has...
Your subwoofer probably has both high-power inputs and "normal"low inputs. The first are for receivers, which don't have link-level output for sub, so they are able to take already amplified signal as input.
You need to use link-level input of your sub and connect it to subwoofer-output of your receiver. The output is marked as OUTPUT - Subwoofer and is black-color RCA plug (don't confuse with subwoofer INPUT under MULTI CH INPUT).
Receiver has only mono output for subwoofer. If your sub has stereo input (white/red RCA plugs), connect just the left channel to the receiver, it will still work.
Don't connect anything to the speaker output on the sub, you don't need that.
Sep 28, 2009 | Yamaha RX-V461 AV Receiver
Rear speakers dont seem to be loud. The front speakers are projecting most of the sound. How do I get the rear speakers to project more sound?
Your settings in the receiver are not set up properly.
You need to adjust the volume output through the rear channels in your receiver.  Review you manual for set up. The issue is in the receiver, not your speakers most likely
Sep 24, 2009 | Coby CSP-94 Speaker
Z-2300 Left Speaker and port dont work
did you try plugging in the other speaker into the yellow output. If you can hear music doing that then its only your left speaker that is the problem. Try tapping the faulty speaker into the palm of your hand while connected. There might be a faulty contact to the actual cone of the speaker. I had to open mine up because i had the same problem. It turned out that it was the wires that weren't making contact. I scrapped and moved them around connected the speaker and it worked. I hope that i made some sense out of this. good luck.
Sep 06, 2009 | Logitech Z-2300 Computer Speakers
Output port for left speaker Z2300
I've been having the same problem actually.
In my situation, turning the volume up and down using the speaker volume control will fix the problem. I only have the faint volume problem at some positions of the dial. turning it up usually fixes it. I'm thinking that opening it up and cleaning it might fix the problem (it used to work with an older set of Creative speakers i had).
If that doesnt work im going to try to get a new remote from logitech.
Jul 02, 2009 | Logitech Z-2300 Computer Speakers
USB port problems
You need the motherboard specs, which you can look up on the internet, based on the maker.
With the USB ports, the front ones often don't include power.
So plug a powered 4 port hub into the front port, and then the hub will supply the power after that.
Jun 26, 2009 | MSI K7N2 Delta-ILSR (MS-6570-030)...
VideoLogic Sirocco Crossfire Logo
Top VideoLogic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a VideoLogic Audio Player and Recorder Expert? Answer questions, earn points and help others
