Question about Syntax LT27HV 27 in. LCD HDTV
I turned the t.v. off at the t.v. not by the remote and walked out of the room. Later that day i went to turn it on and nothing no power light was on nothing at all when I unplug and plug back in no sound or any thing from T.v. any Ideas
  • Doug Thayer
    Doug Thayer Oct 16, 2013
    Thank you your solution was right on the button thank you Mike Wilson
  • 42 Answers
Make sure the power lead is fully into the socket if it isn't integral. Switch on the tv and hold the power button in for about 10 seconds. Make sure the fuse hasn't blown in the plug.
Posted on Oct 15, 2013
Testimonial: "I have power up to the board that the power plugs into nothing out of the board I have visually checked the capacitors and nothing appears to be bulging and no hot spots are visible."
3 Suggested Answers
mikewilson7
  • 8 Answers
SOURCE: I have an Olevia 242tfhd television that just
Same happened with my Olevia 540-B11. You can probably find the details of how to disassemble the TV somewhere online. The problem is poor stress-relief on the cables that plug into the secondary (low voltage) side of the power circuit board (PCB). Once the back is removed you'll find the PCB on the left side with three cables connected to the very top of the board. These cables plug into four clips, 3 horizontal clips side-by-side at the top and one vertical clip on the left side. Unplug these cables, remove the PCB and re-solder the sockets (there are approximately 40 solder points on the back of the board). Reassemble your TV and it'll work just fine.
Posted on Jan 30, 2011
  • 8457 Answers
SOURCE: My Olevia 242TFHD will not turn on. The blue light
The tv have a Tuner board problems,this is the board,that take in the broscasting signal cable.Tries unplug,replug about an hour later.The tv should reset it self and work.Not than tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Posted on Jul 20, 2010
How to turn my TV back on?
are you sure the panel of LCD is not damaged?
Nov 09, 2014 | Televison & Video
Cant get tv to turn on
Try leaving it out of the power overnight. Also, check all the cable connections.
Apr 05, 2008 | Ultra LCD30-500 Television
Why wouldlight work for couple days then not work, after couple hours it works
If you have a remote, change the frequencies in the receiver & transmitter. One of your neighbors must have a remote fan with the same frequency. Also, make sure the wattage in the bulbs are correct.
Oct 01, 2014 | Hampton Bay Dryers
Post Test card reads 43 what does it mean?
when was it manufactured . it has possibly went past it's life expectancy
Mar 01, 2017 | StarTech.com PCI Post Diagnostics Test...
Will not start, will not reset
I have a Silver Moon S558, when I turn it on the power light comes on and a few secords later the red warning light comes on. What is causing the vacuum not to work? One day I was vacuuming, turned it off and a few minutes later went to turn it on and nothing, but these lights turning on. Is there a fix?
Mar 11, 2011 | Miele s558 Silver Moon Vacuum
I have 1998 Chevy Silverado with over 200,000 miles. One morning I started it up just fine, backed out of the drive way, and it just died. I turned the ignition to off, and turned it back on and parked it....
Check your battery terminals. They may be corroded or just loose. If you get it running again have the battery and charger tested at an Advance or Autozone.
Hope this helps.
Rich
Aug 19, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Turn it on!
I have taken it to a TV repair place and he said it was the power supply. 300$ Later.. It is working great!
Sep 13, 2008 | Mitsubishi WT-42313 42" Rear Projection...
I purchased a 7000 BTU portable airconditioner by commercial cool for Haier. I set it up without an issue and was able to turn it on and utilize the remote control to go through all the settings. A...
There may be a master reset switch or combination of buttons to press. The Manufacturer may be able to walk you through this process. Otherwise I would simply exchange it. It sounds like it has a manufacturing problem.
Jun 16, 2008 | Heating & Cooling
Syntax LT27HV 27 in. LCD HDTV Logo
48 people viewed this question
Top Syntax Televison & Video Experts
Computer Repairing
Computer Repairing
Kolbrun...
Jaime Hernandez
Are you a Syntax Televison and Video Expert? Answer questions, earn points and help others
