Question about Sunny Health & Fitness Crazy Fit Massager
Crazy fit massager
Where can I get an instruction manual
I have a crazy fit power massage machine and it cuts off when u turn up to level 6 .
Why not try the contact at the web page for the machine. They may have an answer.
Crazy Fit Vibration Plate for Home Crazy Fit Massage
I noticed the following article as I was Googling information about this machine. It probably predates this machine. Just something to think about.
Shake your way to skinny Experts fear risks
Sep 03, 2017 | Washing Machines
The motor of crazy fit vibration massage does not work, only the panel lights light up
Without knowing what vehicle you have it is not likely anyone can advise you.
Nov 23, 2014 | Cars & Trucks
Why does my crazy fit massage vibrates violently as soon as you turn it on
It would be helpful to have more detailed info, but I;ll take a stab
at it... Usually, when a motorized device vibrates voilently (more
than designed to), it is due to missing parts or being out of
balance in the recriprocating mechanism. Try going over the
machine, again, with this in mind. If you can find another working
machine, make a comparison (perhaps in a local gym?)
Good luck !
Aug 19, 2014 | Sunny Health & Fitness Crazy Fit Massage
Why does the belt keep coming off my Crazy Fitness Massager? I bought this machine second hand so I'm not sure if the belt is the original. It has a Jiali 230J on it. The belt doesn't seem wide enough? Can...
Your pulleys may be misaligned (shafts must also be perfectly parallel) or the belt is possibly too long. Drive belts for fitness equipment here: http://store.beltpalace.com/fitnessbelts.html
They have a phone number to call on their website, too.
Ribbed Fitness Drive Belts for Elliptical Machines PJ Metric and...
Aug 09, 2014 | Sunny Health & Fitness Crazy Fit Massage
Replacing belt
Possible solution- warm belt with hair dryer or shrink-
wrap gun, then try stretching/ pulling over target device. Hope it helps...good luck!
May 29, 2013 | Sunny Health & Fitness Crazy Fit Massage
Crazy fit won't stop vibrating when it has power to it
1) You must test the switch stop.
see the diagram for to fix it.
May 10, 2012 | Sunny Health & Fitness Crazy Fit Massager
I have a crazy fit machine 2010 model, however the belt keeps removing itself, does anyone know how to adjust this please?
Just make sure that the belt is inside of the grooves on the white wheel. That should do the trick. Or ask prestige they will sort it out for you,they are a excellent firm.
Oct 11, 2010 | Sunny Health & Fitness Crazy Fit Massager
Manual for crazy fit massage by action fitness
I have a Crazy Fitmassage but I dont know how to program the machine,help me
Oct 05, 2010 | Sport & Outdoor - Others
Crazy Fit Massager Body Vibration Exercise Machine Repair Manual/Troubleshoot guide
I have a problem with my crazy fit vibration machine it turns on fine but wont vibrate and the belt looks fine and it lights onn up control board but half of the numbers on the light up and missing :/
Aug 30, 2010 | Sport & Outdoor - Others
I carent put the wire throught my pro power multi gym
my crazy fit massage fusion vibration plate machine wont work,how do i fix it
May 27, 2010 | Pro-Fit Exercise & Fitness
Sunny Health & Fitness Crazy Fit Massager Logo
Top Sunny Health & Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Sunny Health & Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
