Blade stuck on 450MD paper cutter. Made a cut and on the way up the blade just stopped and now I can't get it to do anything
  • 67 Answers
SOURCE: Not getting clean/sharp cuts
the blade is spaced too far AWAY FROM THE edge --- it should shear against the edge of the base ---- but only lightly
Posted on Aug 12, 2009
SOURCE: The foodsaver blade is stuck
I have the same problem with the blade. It works sliding left to right, but won't cut right to left. I took it apart and removed the blade and it looks o.k. And cannot find replacement part for it either.
Posted on Feb 01, 2010
SOURCE: changed cutting blade now blade will not stay stable in position to cut
did you get the cutter release knob back in the right place or position?
is the horseshaped bracket damaged in any way?
Posted on May 03, 2012
SOURCE: Toro 50" time cutter when engaging blade loud
I would remove the deck and belt, then spin each blade to isolate the loud noise. Also, make sure the blades are not bent hitting the deck. I always balance my blades after sharpening as well. By isolating the bearings spinning them one at a time, this will tell you where your problem lies. Hope this helps!
Posted on Aug 10, 2013
  • 45 Answers
SOURCE: Can I sharpen the blade on my paper cutter?
You can sharpen the blade on your paper cutter but since they can be hard to sharpen you are better off leaving this task for a professional.
Posted on Sep 29, 2013
Looks like fixya is out of business. ... all zeros in replies.
the zeros you see are "unanswered' questions, just like yours.
Mar 09, 2015 | Martin Yale 620RC Ream Cutter, Sheet...
Removing cutter
Is this a guillotine style cutter or a rotary style cutter? What brand/model? Some rotary cutters are self sharpening and some cannot be sharpened.
Jul 12, 2014 | Tools & Hardware - Others
Not finishing cuts
If you are using a tangential knife, offset is 0. You can change your user to a new one to have all the parameters correctly tuned. Use only original knifes.
http://www.rotutech.com/en/consumibles/851-cuchilla-estandar-tangencial-de-36-5und.html
Mar 25, 2014 | Summa S75-T - 30in Tangential And Drag...
Not finishing cuts
STANDARD TANG KNIFE 36 5X Rotutech
Mar 24, 2014 | Summa S75-T - 30in Tangential And Drag...
What is a rotary paper cutter?
This is a cutter with a wheel-like blade that comes on a rail you can slide along. This lets you make cuts that are wavy or perforations. These are usually used at home becuase they are safer as the blade is wheel-like and not like a knife.
Jan 17, 2013 | Office Equipment & Supplies
What is a paper cutter?
A paper cutter is meant to cut large pieces of paper in a perfectly straight way. The tool is about 30 cm large on each side. It will have a grid drawn on the surface or a ruler along the top. On the right is a blade and it is attached to one corner. The blade lifts up to cut straight edges wherever you wish to cut. There is also a finger guard as a protective feature.
Changed cutting blade now blade will not stay stable in position to cut
Mar 07, 2012 | White Sewing Superlock 1934D Mechanical...
My clippers are no longer cutting. I took it apart today and cleaned out all the hair but I still can't get it to cut. I felt it and it's very sharp it's just not cutting any hair. I have been told it...
there is probably hair stuck between the cutters
remove the cutters from the clipper and you can push the top blade out from under the spring retainer making sure you keep the small plastic runner strip
clean the surfaces and using a flat bladed screw drive insert the blade under the spring and twist slightly to allow the top blade to slide back in
while it feels sharp , it is the sides of the cutter fingers that cut the hair ( like miniature guillotines) and those edges are easily worn off
May 04, 2017 | Remington Precision HC-8017 Hair Trimmer
Aug 12, 2009 | Fiskars Brands Fiskars 12" Portable Paper...
263 people viewed this question
jasbo
jasbo
