Question about Memorex MVBD2510 Blu-Ray Player
When you turn it on all it does is light up the power and the light under the loading door but nothing else works or lights up
Power windows stopped working and dome lights stay on. Power locks work only with the "clicker" but not on driver door
Look under the hood fuse no. 12 should be for power windows. Or maybe something like a bad ground wire in drivers door harness.
Mar 19, 2014 | 2004 Jeep Grand Cherokee
2002 saturn no electrical power nothing works
If you are using a self powered test lamp you will get them results but if it ground to power you have a power cable shorted to ground.
Apr 26, 2017 | Saturn Cars & Trucks
Nothing will power up
Have you checked your ignition switch!
Jun 02, 2012 | Mitsubishi Cars & Trucks
GE 1800 XL not heating, no power, except fan works and clock also
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 29, 2010 | GE XL1800 1100 Watts Microwave Oven
2004 Eclipse won't start. When key is turned nothing happens. No electrical power to anything. No lights in dash , no ac, no power locks nothing except for blinking door ajar and ringing alarm. Even with...
sounds like you have an ignition problem, check the ignition fuse under the hood sounds like the fuse is blown, if that dosent work check your starter solinoid
Jul 01, 2009 | 2004 Mitsubishi Eclipse
Dryer wont turn on
Ours was doing the same thing you would hear a click and nothing but the sensing light. I found the thermal fuse to be blown Part #3392519. Easy to get to through the front cover under the load door. I went ahead and vacuumed and cleaned out the inside and vent tube.
Jan 21, 2009 | Whirlpool GEW9250 Electric Dryer
The door is locked shut and the power will not go on
Now that you have plugged it back in, do any of the lights come on, any power? Or does the door just not open? thanks
Dec 15, 2008 | Washing Machines
Nothing electrical works
the main terminal is a heavy red wire attached to the fuse block it should be clean and tight. also you can hook a test light from the battery neg. to the terminal it should light. if it doesn't light you could have a bad engine ground (primary ground). or a poor connection tot he main fuse block terminal previously mentioned
Sep 29, 2008 | 2002 Chevrolet Blazer
Memorex MVBD2510 Blu-Ray Player Logo
16 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
