Question about AudioBahn A2300HCT Car Audio Amplifier
Red light i made a spark when my v12 line from my amp came off and touched the back of my amp but my subs where not hooked up at the time and now the protect light is on the red one and i cant get my subs to make noise
  • 4 Answers
I would check the fuse too see if you blew it or not also check the one up next to the battery also. if all ok i wouldnt know what could be wrong
Posted on Oct 07, 2007
Kenwoood kac-7202 redlight/no output
you blew the output Ic's (amps one or more ) you can fix this by replacing the output IC's
Jan 29, 2014 | Kenwood KAC-7202 Car Audio Amplifier
I need to know how to hook up an alpine v12 amp 2 ohm i have two tens
This really depends if your 10" subs are 4 ohms each or 2 ohm - for this exercise, I'm presuming they are 4 ohm each.
You already know your amp can deliver 600W RMS (@ 2ohm), so you need to be careful you do not exceed the maximum RMS input power of your subs.
Normally you would wire subs in "parallel", which would reduce the circuit load to 2ohms - however, the 600W RMS power may be too high for your subs to handle.
In this case, it may be safer to wire your subs in "series" - this will increase the circuit load to 8ohms, which will effectively decrease the amps RMS power output.
Cheers,
Sep 05, 2011 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Subs wont work or do anything when hooked up
Check your safe light on your amp if it's green then the subs are **** but if you don't have a green light check your ground, just because it sparks when it touches dosen't mean it's a good ground so grind the paint off the bolt if need be. If all else fails get new subs, do your self a favor don't get lanzar products there horrible trust me on that one
May 11, 2010 | Lanzar (Pair) MAXP104D Max Pro Series...
My subs/amp are not working
when you car is running, it charges the battery somewhat. So the voltage problem is not a problem. The red light means the amp is going into ''Protect Mode". This usually happens when something is wrong with the amp. Usually the amp is getting hot. Check all of you connectiong and check the final impedance of the subs. Make sure the amp can handle the impedance of the subs. If you need anymore help, message me.
Feb 12, 2010 | Kenwood Excelon KAC-X621 Car Audio...
One speaker is working more than the other
I would replace the wire your sub is hooked up to and try hooking up the sub that was sparked to the opposite channel on the amp to make sure the amp is not the culprit. Also switch RCA cables L to R, R to L
Feb 02, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
I need help
Most of the time if the red light is on the amp is no blown but some times it does this cause the subs are hooked up in the wrong way. If the amp is only 2ohm stable and you hook the subs up to it at 1 ohm than the amp will not work so I would check this frist.
Oct 17, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Music not playing from subs
Do this for the sub amp...
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jul 03, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Amp and Stereo hooked up, no sound coming from the sub
It sounds as though either the sub or amp is blown. When an amp blows quite often the light will still light, but the internals are trashed. The only surefire way to tell whats going on is to use a Digital Multi-meter to check the impedance of the sub, and the voltage at the amp. You can get a multimeter as cheap as $10 at most autoparts stores, Radioshack, Sears, etc...
Also, always post brand names and model numbers, because more info equals more help.
Apr 30, 2008 | Car Audio & Video
SUBWOOFER NOT WORKING?
if you have real old wires from the amp to the sub try getting new wires on it. check the little wires that go to the cone itself on the sub. sometimes they can manage to get pulled out of their terminals and make sure that thier touching the terminals on the correct spot
Sep 29, 2006 | JBL GT150 Car Subwoofer
AudioBahn A2300HCT Car Audio Amplifier Logo
69 people viewed this question
Top AudioBahn Car Audio & Video Experts
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Jerry Naidoo
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
