Question about Cobra 29 LTD CB Radio
Should the calibration needle be all the way in red
    Novelist:
  • Cobra Expert
  • 500 Answers
On cobra 29's theres a small arrow on the top line next to the red part of the meter.. thats the starting calabration location.. then when you set it to read the SWR.. it should go back left to the green.. you want it to be 1:1 and should try for no higher than 2:1 if its higher there may be antenna system problems..
Posted on Oct 21, 2013
Babylock 6 needle calibration
Needle calibration? Are you asking about timing? You can search the internet for videos or instructions on how to set serger/overlocker timing.
Feb 07, 2016 | Sewing Machines
When my calibration needle is all the way in the area my swr is really high
When your needle is all the way in the RED, your swr IS really high. That's what the meter is telling you. You need to clean all of the antenna connection points and adjust the length of the antenna to reduce the SWR (standing wave ratio) which is basically resistance to transmitting signals.
Oct 15, 2013 | Cobra 29 LTD CHR CB Radio Chrome Special...
Should my calibration needle be set all the way in red on my cb
If you are talking about where it should be on the meter, there is a wide mark where the needle should be.
Note this is only a reference meter it does NOT adjust your swr.
Screen calibration screwed up.. need to know how to reset it?
You can get back into the touch-screen calibration routine if you start up the machine with both of the needle offset buttons pressed at the same time ... once you've calibrated the touch-screen you'll be OK again.
Dec 30, 2012 | Bernina Artista 180
How do I set a imperial hvac guage
Are you trying to zero the gage? They have 3 types of calibration setups, so it will depend on the one you have. Be sure there is no pressure in the line, purge any lines or open the hand valves. Remove the plastic cover (should screw off by hand). Now some have a very small screw built in to the stop post, this post is a rest for the needle. if it has a slot turn this screw to set the needle at zero. Next is a slot on the center of the needle hand itself, look close and you will see a small center pin and a slot on ether side of that center. Use a small screw driver hold the needle hand and carefully turn the center one way or the other to re-zero the needle (may take a few trys). Next is a calibration screw built into the face of the gage (this is the easiest to do) turn it to zero your gage. Hope this Helps Fixya up.
Apr 25, 2011 | Heating & Cooling
I need to calibrate the bobbin with the needle. is there an easy way to do this. i changed the belt which is why it is out of sync.
There is no easy way to calibrate. the whole system is simply mechanics so you'll have to take the belt off, calibrate manually and reinstall the belt carefully not to throw anything off.
Thanks,
Pat
Aug 16, 2010 | Brother CS-80
29 LTD CB Radio: Calibrate cb radio...
The CAL is to calibrate meter for reading SWR (standing wave ratio) which is reflected power when transmitting back to receiver(radio) from antenna system.
This CAL switch position when selected and mic keyed uses the CAL knob to align the meter needle with inverted red triangle next to cal on meter. Then when you select SWR switch position meter will display accurately when mic is keyed for that channel. Now notice the difference when you go between channels 1 and 40. The ant led light will act as idiot light if it is not lit then you are most likely safe to transmit.
I say system because your vehicle, antenna and coaxial cable are all part of this system. When you have a high reading and have to trim you antenna this is really calibrating the antenna to the vehicles body which acts as a ground plane.
May 16, 2010 | Cobra 29 LTD CB Radio
On my huskystar em 10 the red light is lit up by errors and then it says e 15 it had previously said e11
Hello, The erroro message #11 is when the needle bar is too low for the sensors to align properly. If you rotate the handwheel (always towards you) slightly until the needle is in it's highest position the machine should calibrate or "set up" correctly. Error message 15 is telling you to raise the presser foot lever, so the machine can calibrate also. It's a safety measure so the hoop doesn't hit the foot. If the machine were allowed to calibrate while the foot was down and the hoop was left on the machine as well, the hoop could slide into the foot and damage either the foot or the hoop.
Oct 17, 2009 | Husqvarna Viking 1
Thread jammimg on the underside when sewing
This is usually caused by the machine being out of sync. The first thing I would try is a brand new needle. Even a slightly bent needle can cause this problem. Make sure the needle is in correctly and tight. Next make sure you treaded the machine correctly, making sure that thread goes into the top tension properly. The top tension should be calibrated to be in the middle. I would slowly turn the handle making sure the stitch looks proper. From there try tightening or loosening the tension until the loops on the underside start to get smaller until they look tight but not too tight or you'll start breaking the top thread.
I would use a standard 14 needle with some standard medium weight cotton to calibrate the unit.
Hope this helps. Let me know your results
Aug 23, 2009 | Euro-Pro 416 Mechanical Sewing Machine
Calibration of the sphygmomanometer
Unscrew the silver ring from around the dial face. Lift off the clear cover. Gently pull the needle off the pin. Re-align needle. Gently push the needle back on to the pin taking care not to push to hard or bend the needle. I hope this corrects your problem.
Jan 27, 2009 | Moore Medical Blood Pressure Kit W/...
Cobra 29 LTD CB Radio Logo
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
