Question about Hoover F6055-900 SteamVac Maxextract LS Wet/Dry Vacuum
My max extract 77 hoover wont spray - Hoover F6055-900 SteamVac Maxextract LS Wet/Dry Vacuum
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 47 Answers
Make sure all water lines are not clogged with anything 1st. Then check to see if the switch/lever or button that actuates the spray is functioning/working. If it's a mechanical switch/lever etc, see if you can take it off and clean it thoroughly and check to make sure there are no broken parts. If it's an electrical switch/button or lever, you need to check and make sure it's clean, and all the contacts to wires are NOT broken or damaged. You may have to replace parts if they don't function.
Posted on Oct 19, 2013
  • 3 Answers
SOURCE: i have a hoover steam
You probably have no suction and that is because the aluminum flywheel has broken apart under neath the blower motor. (cheap construction) I know I just figured it out on my unit.
Posted on Nov 27, 2008
  • 240 Answers
SOURCE: i cant get the brushes
Remove the brush assembly and insert a flat screwdriver into the square hole and be sure it turns. If it is seized up, the turbine assembly will require replacement. If it turns, be sure the brush control is set to the brush position and the filter is clean. The filter may be on top behind a clear plastic cap, or underneath in red plastic holder depending on the model. The brush will also not turn unless the lower tank is in place, and the handle released and tilted back.
Posted on Jan 28, 2011
aquaman987
  • 927 Answers
SOURCE: the brushes on buttom dont spin already exchanged
Is there a switch for TOOLS or VACUUM?
Posted on Feb 03, 2011
  • 1833 Answers
SOURCE: Fairly new Hoover max extract won.t turn on.?
Check the power cable, and internal circuit board if there anything burn out or fuse burn.
Posted on Jun 07, 2011
SOURCE: I can't get my Hoover max extract platinum to
First this is complicated to diagnose with it not being in front of me. Where i would start if i were you is make sure it is all together correctly or simply take it apart and put it back together make sure all is there and seated proper and try it again also if you feel no resistance or hear no clicking sound from the on switch it just may be bad.
Posted on Apr 08, 2012
My Hoover max extract 77 will not turn on why
The power switch's in those machines are crap. You can take the handle assembly out and replace switch with a new one. When took apart check voltage at switch to make sure you have power there. If no power, replace cord
I’m happy to assist further over the phone at https://www.6ya.com/expert/matt_0c9009be7d775298
Jul 24, 2015 | Hoover Vacuums
Hoover max extract 77 manual
Hi! Follow the link below to view the manual for the FH50240. Hope this helps!
http://hoover.com/file/611/
Jul 19, 2014 | Hoover Max Extract 77 Carpet Cleaner -...
Hoover max extract brushes wont spin
Check that the brushes are not jammed up with hair and fluff.
Remove the brush from the housing and clean throughly including the bushes/inserts and belt
Hope that helps
Feb 09, 2014 | Hoover Platinum Carpet Cleaner With...
Hoover max extract 77 water tank leaking
Remove the little black plastic plug on the bottom of tank (has a metal spring around it), that is where it is leaking. Wrap Teflon (pipe tape) around it and the spring. Replace black plug. Not a permanent fix, but can help if you are on a bind. It worked for me.
Sep 09, 2012 | Hoover F5505 SteamVac Spot Vacuum
Fairly new Platinum series Hoover Max extract wont turn on
I have the same problem. Fairly new machine, only been used a handful of times and now it wont turn on.
Feb 18, 2010 | Vacuums
Hoover F6055-900 SteamVac Maxextract LS Wet/Dry Vacuum Logo
360 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
