Question about Bosch Ovens
Transistor replacement motherboard transistor for bosch fridge freezer reg nr. .6601
Where i ca get manual for hbn412agb
Posted on Oct 24, 2013
I need a thermostat for bosch oven serie Nr HEK66X83EH/01. FD8708
Fixya does not sell replacement thermostats. Check with a local appliance parts supplier.
Jul 20, 2016 | Bosch Ovens
I have a Bosch over which I bought second hand but there is no markings on the oven switches the number on the door is E-Nr. NKT665CEU /01 FD7902 005189 and Typ.GKB-200 Please can you help?
Look up the front panel at an appliance supply store- copy the pattern and go from there, or buy the new panel with new markings...
Jun 17, 2016 | Bosch Ovens
Flavel fridge freezer
you may have it to close to the wall and ur out of freon
Dec 06, 2013 | Ovens
Lamona fridge freezer
check that the temp setting knob has not been turned to zero for the fridge. The light is only to let you see what is inside the fridge and is not an indicator of the fridge working.
Jun 26, 2013 | Ovens
I have water pooling in the bottom of my fridge, what would it be
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
Apr 27, 2012 | Ovens
Fridge side won't cool down, but freezer is fine
very common freezer is where the cold starts then the fan pushes it to the fresh food side/ your air control adjust the tempt for you . the problems that cause your problem are frost build up o freezer coil . look in freezer for frost on back . listen for your fan when you open the door . if frosty the defrost system has failed and no fan no air flow . the freezer will have problems to . see what you can and get back with me .
Dec 05, 2009 | Ovens
Water works but icemaker does not. the freezer barely cools
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Nov 11, 2009 | Ovens
Our power went out tonight for 20min and after it came back on, the light and temp displays in our Frigidaire fridge/freezer does not come on. The freezer light appears to be working and it sounds like the...
Your display panel went out and needs to be replaced. This is a fairly easy part to replace. Just call us and we'll ship your part out asap!! We look forward to working with you!
Oct 18, 2009 | Frigidaire FEB27S5A Electric Single Oven
GE Monogram Fridge/Freezer
A frosty freezer in the back panel is an indication of a defrost failure issue. Problem may lie in the the control board, heater or defrost terminator. The problem usually is a broken defrost element. Hope that helps :)
http://tclaundryrepair.com/
Feb 25, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
Oven will not heat after self cleaning
We used the self cleaning feature on our RBS305 Built In Electric oven and afterwards it would not heat. replaced the Fuse-Thermal part Nr 9759243 (which is the new part number. (Shown as Nr 37 on the Parts list for the oven parts). Cut all Power to the oven off and it was very easy to pull oven out with help of my wife. Removed back, bought a new part for 49.55 plus tax. Put in new part, replaced back and oven works like new. I am a 73 year old senior so when I say it is fairly easy to replace you know it is. Hope this helps someone
Dec 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Ovens Logo
59 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
