Question about Dirt Devil Vacuums
No power shut off while running.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
Could you please rephrase your question. I don't understand it. If you mean that the vacuum won't shut off, just pull the plug. Joking. It's in the switch, that will have to be checked, cleaned and maybe replaced.
Posted on Oct 19, 2013
If my overload protecter reset part is broken wont that stop the moter from running
It's possible the motor may run if the reset is broken but it may prevent the motor from shutting off properly in case of an overload.
Apr 01, 2016 | Kenmore 24212 Whispertone Bagged Canister...
Will not maintained power in high setting. Runs fine in low power setting.
I would recommend thoroughly cleaning all filters, most likely the high setting is overheating the motor and the thermal protection circuit is tripping. In other words, the motor isn't "breathing" well.
Mar 15, 2016 | Electrolux 2-in-1 Stick Handheld Vacuum,...
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Dec 03, 2015 | Rainbow Vacuums
Vacuum works but won't shut off
Switch is broken in the "ON" position. Just plug it into a power strip outlet and use the switch on the power strip outlet to turn it on and off.
Nov 08, 2015 | Vacuums
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
My unit is a little over 2 years old, and I cannot leave the power button in the on position on the main unti any more. The power was controlled by the vacuum power nozzle whether I was using the carpet...
Why can't you leave the power switch "on" ?
Does it stay running, ot does it not run at all?
if it stays on, the power probably isnt controlled by the power nozzle, but may be controlled by a door switch on the flapper doors where you insert the hose... Make sure all the "flapper doors" are completely shut, there's probably one stuck a little open I'm guessing...
Oct 22, 2010 | Broan-NuTone VX475 Bagged Central System...
Electrolux Oxygen 3 model 7020A contols not working
You need to replace the hose itself. The buttons in the handle a very cheap and go bad all the time.
Aug 17, 2009 | Vacuums
Vacuum will not shut off
Sounds like you have wires crossed at the switch. The 2 wires coming in go to the center posts, 2 to the power head & 2 to the main motor.
Jan 31, 2009 | Kenmore 25512/ 25513 Progressive Canister...
No suction for use of crevice tools, running hot, then shut off
Obviously no suction in hose would indicate a blockage, over heating is a breaker that shuts off the machine when it over heats. There is no way to clean hose the on this model because the hose does not detach at either end, therefore I had to employ the use of the good old wire hangar. Job complete up and running, with good suction. It is amazing what a prayer to God can do.
Nov 17, 2008 | GE 106766 Bagged Canister Vacuum
Vacuums Logo
93 people viewed this question
Top Dirt Devil Vacuums Experts
Nick Olsen
JoeVacs
Are you a Dirt Devil Vacuum Expert? Answer questions, earn points and help others
