Question about Jenn-Air JMV8208A Microwave Oven
Hello my JENN AIR Jenn Air JMV8208BAS Microwave won't turn off properly. When it comes to the end of the cooking time it beeps and the vent at the top closes but it keeps making a noise and it is still cooking. The only way to stop it is to open the door, but if you close it again it carries on going. Help! thanks
  • Jenn-Air Master
  • 9,085 Answers
I would first suggest checking the bottom door switch and its mount.
See these help files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
The full service / installation manual is here.
If it's not a switch issue, you may have a sticking relay on your control board, which can be economically repaired. Details are here.
Posted on Oct 17, 2013
  • 212 Answers
SOURCE: microwave exhaust door stuck in open and close cycle.
Depending on age You might need a new one. A repairman might be able to fix it.
Posted on May 24, 2009
  • 4088 Answers
SOURCE: HOW TO REPLACE BLOWN FUSE
Look for a reset button on the back--push to reset. If trips again, unit has probable short.
Posted on Jul 12, 2009
wpcustomer
  • 362 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My JENN-AIR Microwave Oven stop
    Hi, my name is Audrey and I am a Jenn-Air employee. I would appreciate the opportunity to assist you with your microwave. Please send me an email through our customer service address,
    NAR_JennAir_CustomerExperience@JennAir.com
    and type 'Attention: Audrey' in the subject line. Please include your full name, phone number, and model/serial number, and I will look into the issue for you.
    Posted on Oct 27, 2010
    SOURCE: Jenn-Air Microwave vent grill opens and closes
    I have this same problem occasionally. Pull the vent grill open and look for a white cam that rotates when the microwave is on. To the right of that cam, there are two gray switches. The bottom switch should have a red tab that pops out. When the vent grill opens and closes continuously, the red tab is stuck in. Take a flat screwdriver or tooth pick and push gently in on the red tab to release it. It must get stuck due to grease or dirt accumulation. Good luck.
    Posted on Oct 19, 2011
    SD Tech
    • 14553 Answers
    SOURCE: jenn air microwave loose door
    Most if not all of these units have a safety switch--can't get at it from the outside---if unit is taken apart it often is snapped into a plastic holder and prevents the unit from working if door is open.
    If it is loose or not engaged completely the unit will do what you are describing.
    Posted on Jun 16, 2012
    Jenn-Air jmc2430 built-in does not run.
    Hey David... sorry to say
    There's a $14 fuse between cooking & your magnetron (could be other things (but in my opinion... magnetrons sound right for your symptoms)
    I checked for your magnetron
    and got MFR Number 461967847321 - not AVAILABLE.
    (there is one $74 on eBay (
    very bottom, below)).
    I LOOKED at your oven and it is a really nice one...
    So I think I'd be hitting all the on-line parts houses
    to see if you can locate one...
    Jenn Air jmc2430 built in does not run
    http://www.appliancepartspros.com/whirlpool-magnetron-461967847321-ap5987313.html
    461967847321 NEW MAGNETRON WHIRLPOOL KITCHENAID MICROWAVE NON OEM WITH...
    May 15, 2016 | Jenn-Air Microwave Ovens
    Jenn-Air Microwave (Model Number : jmv8208bas) sparking
    If you wish to get some details; check the site linked here. Pull up older posts.....
    http://electro-medical.blogspot.com/
    Apr 10, 2016 | Jenn-Air Microwave Ovens
    Jmv8208bas manual
    http://kitchen.manualsonline.com/manuals/mfg/jennair/jmv8208bas.html?idProd=1511577 Free Jenn Air JMV8208BAS Microwave Oven User Manual ManualsOnline com
    May 21, 2014 | Microwave Ovens
    Ihave a Jenn-Air JMV8196 microwave oven. The clock works,the fan works and the light works. Not sure why the microwave will not come on to cook. Help?
    The problem is caused by one of three things, the magnetron "heats food" the high voltage diode "sometimes shorts" or the high voltage capacitor " shorts"
    Mar 10, 2012 | Jenn-Air JMV8196 Microwave Oven
    My JENN-AIR Microwave Oven stop working, no light is coming in front pennel, I checked power exist in wall outlet, I suspect some kind of fuse blown into microwave oven, my microwave oven make & model...
    Oct 26, 2010 | Jenn-Air JMV8208A Microwave Oven
    Lock function reset for model JMV8208BAS
    The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
    If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
    The owner's manual is online here and it covers the child lock:
    To set the child lock.
    Touch and hold
    ENTER/START
    pad more than 3
    seconds. CHILD
    LOCK ON will
    appear in the display
    window with two
    beeps.
    To cancel the child
    lock.
    Touch and hold
    ENTER/START
    pad more than 3
    seconds. LOCKED
    will disappear and
    you hear two beeps.
    Aug 18, 2010 | Jenn-Air JMV8208BAS Microwave Oven
    Jul 11, 2009 | Jenn-Air JMV8208A Microwave Oven
    Jenn-Air JMV8000BAW
    I always recommend that folks use the vent / hood fan anytime they're cooking with the stove.
    Was it on at the time?
    If not, moisture can certainly get into the works and cause problems or damage. If it dries out, it's fine but if not, it could cause damage.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Feb 15, 2008 | Jenn-Air JMV8208AAS Microwave Oven
    JMV8208AAS Jenn-Air runs all by itself
    check the door connection. it may be stiking. unplug from the wall and open up, spray wd40 and give it a clean.
    Dec 13, 2007 | Jenn-Air JMV8208A Microwave Oven
    Front vent on JMV8208A Jenn-Air Over-the-range microwave hood keeps opening
    There may be an option to turn that off with the keypad, but your best bet would be to contact Jenn-Air.
    The manual will have their contact info or you can see: http://www.jennair.com/content.jsp?name=contact_us
    You can download the owner's manual and installation manual here:
    http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMV8208A&siteCd=JA_EN_US
    Dec 03, 2007 | Jenn-Air JMV8208A Microwave Oven
    Jenn-Air JMV8208A  Microwave Oven Logo
    157 people viewed this question
    Top Jenn-Air Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
