Question about Dometic RM2652 Refrigerator
I have a Dometic RV refrigerator Model RM 2652. After starting the unit up it cuts back off in a minutes. Checked and found out not getting power to the unit. When I plugged straight in to another outlet it blows the breaker. Not staying on with gas either.
    Sergeant:
  • 405 Answers
On the back side of the refrigerator to the right you will see a couple of wires going into a metal rod that is bent. That is the electric heating element. Grasp hold of the metal/rubber booted end and see if you can move it from side to side. If it will not move then that typically means that the heating element has failed and has welded to the cooling unit. When this happened it not only could cause a short but could also rupture the cooling unit causing a loss of the hydrogen/ammonia mixture. If they are moveable then you may have a bad circuit board that is causing the unit to shut down to protect the other components.
Posted on Jul 02, 2014
  • 20 Answers
SOURCE: Rm 2652 stays on a while then cuts off and stays off
If you have the yellow epoxy filled circuit board from around 1993-1996 rather than the green newer one you can see the circuits on (take the black cover at back of fridge off to check) it is most likely just a bad circuit board. Otherwise it is most likely low voltage or a bad ground on the 12volt power coming into the fridge. Also make sure your thermostat(if available) is on maximum during testing.
Posted on Feb 20, 2009
  • 93 Answers
SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Posted on Mar 15, 2009
pride applia
  • 232 Answers
SOURCE: Dometic RM 2652 has no power and blows fuse in the
brand and model # please
Posted on Jul 02, 2009
SOURCE: How many amps does a unit like this use?
According to the label (inside the hinge of the main door), it's 2.7 amps when running on 110 volts. It shows blank for running on 12 volts. However, with the anti-humidity switch on, it can use enough current to drain your battery. I was concerned about the battery draw when running the fridge on 12 volts, because the dealer told me it defrosts itself every 72 hours. Something has to control this, and probably uses some power.
Posted on Jul 25, 2009
SOURCE: RM 2652 will not get cold
Check the 5 amp buss fuse behind the frig.
Posted on Apr 10, 2010
RM 2652 RV refrigerator runs on gas, not on AC. Power surge took out power converter and refrigerator power module. Replaced converter and power module. All display panel lights working. Cools great on...
just had same thing happen to mine. replace control board. starting working on gas. one the ac I then replaced the ac heating element and now working great on ac
Mar 21, 2011 | Dometic RM2652 Refrigerator
Dometic RM 2652 Doesn't Cool smells of amonia
There is a recall on this product. Go to www.Dometic.com and look for the recall info...or try this link http://67.238.126.140/recall.php put in your model and serial number to see if yours if a recall...I believe it is and I have found the problems you are talking about at this website http://www.gasrefrigeration.net/Why%20they%20fail.htm. which is exactly why they are recalling this model refrigerator. Hope the links help...if not go to the first link and look for the recall page and you will be able to see if it applies to your rv refrigerator. Hope this helps!!!
Sep 14, 2010 | Dometic RM2652 Refrigerator
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
Apr 04, 2010 | Dometic RM2652 Refrigerator
Feb 01, 2009 | Dometic RM2652 Refrigerator
Dometic rv refrigerator
I found that they rewired the 12 volt supply, red wire, thru a heat safety switch on the burner unit and it was open instead of being closed and cut off the main 12 volt supply to the control board. I connected a jumper wire around the new switch and the frig works . either the new switch is bad or too close to the heating unit.
Oct 22, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
109 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
