1998 Nissan Pathfinder Logo
Posted on Apr 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine bk firering & lose of compression.
When first starting truck and driving no problem after 10 minets truck begins to back fire and when i excelerate it loses compression and wonts to stall i have replaced fuel filter, gas tank , new plugs and wires,fuel filter,air filter. put fuel injection cleaner in tank and still have same problem.my tack gage fluxuating up and down. please help.
s_pra_army
Level 2:
Scholar:
  • Expert 37 Answers
  • Posted on May 10, 2009
s_pra_army
Expert
Level 2:
Scholar:
Answers
37
Questions
0
Helped
33198
Points
141
Backfiring after warming up can be from many things.
One that comes to mind is carbon deposits on valves, causing them to not close properly. The carbon deposits would also heat up and then ignite air/fuel mixtures before the spark plug can fire.
Or you would have hot exhaust gasses leaking back into the cylinder on intake and that would ignite the fuel.
Tac gauge fluctuating, and engine running rough on acceleration could be a vacuum leak, do you hear a hissing sound when the engine is running? listen closely under the hood. If you have a vacuum leak you would lose power and your RPM would fluctuate oddly. As for the backfire however, there are probably more than just one problem. Its hard to say for sure.
So please, more details, noises you hear, when exactly everything happens etc.
What speed and RPM the engine begins to bog down at, does it stall? What range is ur tac fluctuating at? anything you can think of, throw it on there.
Hope this helps you
2answers
Out of the blue . truck looses power and wants to die. not letting it die by hitting gas peddle it runs but starts back firering supper bad. truck dies .starting up it doesnt want to put . made it home .....
if you have replaced cap and rotor plus coil and it seemed to fire up then i would take the next step. For sure put your new plugs and wires on then make sure you have replaced your air filter, and change out your fuel filter, fire up the vehicle if it doesn't start I would suggest changing the fuel pump. If it starts up make sure you put in some BK fuel injector cleaner in your fuel it might be you have dirty injectors. If all fails then get back with me and we will look else where. Good luck hope this info helps you out
Cut out wont start
all cars , gas (otto cycle)
it only takes 3 things to run.
good engine. (compression test time number of cylinders) WOT.
good spark. (test it)
good fuel mix. (spark tips wet or dry)
if the engine is good, and the spark is hot and timed right.
try test fuel if engine is not flooded, (is it?)
try test fuel, if tool less or no money for a real mechanic.
see scotty do it here, (this only works 80% time) skip ad
http://www.youtube.com/watch?v=064Ilsz8Fzg&NR=1&feature=fvwp
posted now 100 times.
1helpful
Ignition timing mitsubishi triton 2003 3.0L GLX
Depending if it is backfiring out carb or out exhaust will tell you if the time is off. The carb backfire is a sure sign the timing is off. A valve is not completely sealed off before ignition and it explodes before sealing off the chamber. This also could mean a burnt valve as well.
AN exhaust pipe backfire could be a few things. Raw fuel in muffler that ignites from the heat. Over rich mixture, timing, jump timing belt, clogged catalyst, etc.
Now your vehicle runs on LPG which actually is a good thing. Much cheaper then gasoline fuel. I am not familiar with LPG carburation methods, but backfires are pretty basic. Carb or exhaust fire, timing is a good direction and carb adjustment. I would do a compression test also. Check for a leak that is not allowing a full burn of the fuel in the chamber. Check vacuum lines also.
If Timing the vehicle requires a short between 2 points, it must be done to show correctly the proper setting without advancing the timing. As long as the distributor has not been removed and placed a tooth off which is rare, but jumped timing belts will set a tooth off occasionally. Do a compression test, it will let you know your engines condition accurately.
2answers
My 95 lumina shakes and misses while accelerating tried plugs,wires,oil chage,air filter,fuel filter,oil filter,1 coil pack,1 rear exhaust push rod and lifter
honestly, sounds like you should go to basics-check compression first, clean the throttle body , check fuel pump pressure at the rail on top of the engine-if you have any kind of check engine light, you need to get the code pulled, you have an OBDI system, so it is not as easy to diagnose-another basic is having good electrical power-battery and alternator in good condition.
When I drive the lumina about 20 miles and brake to stop engine dies. Will restart in park but as soon as put in drive or reverse it instently dies after it cools about 10-15 minets can restart and drive
a bad crank sensor causes a car to shut down while driving down road. and will not start back up for about 10 minutes. have car scanned to read the problem codes. any auto parts stores will scan for free.
1helpful
first you buy a dictionary and learn the english language, then sell that piece of **** and buy something made in this country in this century
2answers
My truck is getting fuel but wont start
Three thing and engine need to crank are fuel fire and compression so if you have the other two then you are losing compression i would suggest running a compression test on it. I hope that helps you out.
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
