Question about Bosch SHE43P05UC Builtin Dishwasher
The pump in my Bosch dishwasher will not turn off, even with the door open. During the last washing some water (though not a lot) came out on the floor. I have run what I believe is the diagnostic routine and I first receive the code C6 with the buttons held down. When I release the buttons I get the code PO (or P0) and the "regular wash" light is blinking. When I press the "regular wash button" I get the code E1. What is my likely problem and what is my best course of action? This machine is about 1 year old.. 1.
  • 77 Answers
It could be the floating switch that is jammed leading the machine to think that there is water in it or it could be your pcb.
Posted on Oct 15, 2013
  • 1 more comment
  • Douglas Winkeljohn
    Douglas Winkeljohn Oct 16, 2013
    What would account for the water on the floor?
    I found water in the base of the unit and mopped it out, which has stopped the pump from running. I also removed and disassembled the control unit, looking for the bad solder joint that someone mentioned, but found none, so I have reinstalled the control. I still get the error codes when I run the diagnostic. Now my big question is why did the unit have water in the base and some water on the floor?
    I found the (freak) source of my problem! There was a pinhole leak in the rubber coupling on the end of the drain hose that attaches to the machine. It is right on the molding seam on the coupling - obviously a manufacturing defect. The freak part is that the leak squirted right through an opening in the machine frame, ending up in the pan below the machine. Only a small amount actually got out to spill on the floor. The rest was almost all carried away by the pump - although the leak assured that the pan was filled over and over - pumped out - leaked back in - in an almaost never ending cycle. A replacement hose should do the trick.
4 Suggested Answers
SOURCE: Problem with Bosch built-in Dishwasher Model SHU6806UC
I had the same problem and just today replaced the control board module. Purchased the control module online and installed in myself. Was not that difficult. undo the screws (torx screw driver needed) unhook the connections to the board and label all. Pull the board out and open, found burned connectors. Now works like a dream.
Posted on May 30, 2008
Macmarkus
  • 2605 Answers
SOURCE: I have a SHU43C05UC/22 Bosch Dishwasher. The
Welcome to FixYa.
Based on your description I'd say the issue is with the control...unfortunately.
The number"1" being displayed ( on models with the display like yours ) is actually an error code indicating a fault in the heating process.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the serial number so you may want to contact Bosch to inquire if yours is affected.**
http://microsites.boschappliances.com/safetyrecall/dishwasher/
or
Bosch dishwasher hot-line 1-800-856-9226
1-800-856-9226
Before calling, have the model and serial numbers on hand. A live operator can be reached at the hot-line 24/hrs day.
Those not affected by the recall still can be a problem but easily fixed. As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Your control WILL differ in appearance, however the issue, the service and all the same info applies...except the part number. Yours will be # 431692**
**Flip this over and inspect the solder joints, it will be obvious when you see it...the cover for your models control comes apart in a similar manner**
This is where and what to look for, except I`ve re-soldered this one already...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed, other-times it will eventually stop or display "1".
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control ( # 431692 @ approx. $150 - $250USD...$167.99 at "searspartsdirect.com" ) and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 31, 2010
SOURCE: When I press the start button, Bosch dishwasher
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Posted on Feb 04, 2011
How to fix a bosch dishwasher?
Run away. It is not a do-it-yourself project, as these machines are complicated beyond normal reason... Call a technician, trust me.
Jul 08, 2016 | Bosch Dishwashers
Bosch SHU runs even when the door is open, what do i need?
Hi Jeffrey,
This depends what you mean by "runs". If the dishwasher continues with a wash cycle - i.e. circulating water - with the door open, the simple answer is that you have a defective door microswitch.
However, I suspect what you perceive to be the dishwasher running, is actually the drain pump running continuously. This happens when the anti-flood protection system has been activated and continues even when the door is opened. The simplest way to check is to open the door (while it's "running") and pour some water into the tub. If the water drains away immediately, this shows the drain pump is running and the anti-flood protection has been activated.
This may be due to water having leaked into the base of the dishwasher, but it could be as simple as a stuck or defective float-switch.
Please try the simple test above then post back for further assistance. If you're planning to investigate or repair this yourself, you're going to need a Torx T20 screwdriver and a multi-meter would be useful as well.
Regards, BElectric
May 25, 2011 | Bosch SHU9915UC Dishwasher
I hear my water heater turning on and off during the cycle, but when I open up the dishwasher at the end of the cycle, the dishes are lukewarm, and sometimes there is still soap on them. This is...
it sounds as though the water level during the wash is too low to check put machine on let it run for 5mins then open the door once the water settles the level should be just below the salt cap no lower if it is then you have a pressure chamber problem water level is critical on these machines as the heater will not turn on till correct water level is reached.
Nov 01, 2010 | Bosch Integra 300 SHX33M05UC 24 in Builtin...
Dishes not washed detergent still in compartment pump will not stop pumping bosch dishwasher
cycle stuck possibly..........unplug it or turn it off at the main electric box circuit breaker......wait 10 minutes and try it again.........
Feb 13, 2010 | Bosch Dishwashers
My Bosch dishwasher, S9J1F will not clean things properly, I've changed the arms, cleaned it. I think the arms don't seem to spin properly, (I bypassed the door switch so I could see them spin)I have tried...
not enuff water in it or pump blockage or bad pump impeller. if you ran it with the door open even if the arms didn't turn you should have got drenched is the bottom covered with water about 1 inch deep some times the fill valve screens get clogged and don't let in enuff water if plenty of water in it look for somthing in the pump
Dec 08, 2009 | Bosch Dishwashers
My Bosch SHV46C dishwasher keeps running, even when the door is open, unless you turn the control switch off. Then, when you turn the switch on, it starts running again.
I have a Bosch that was stuck in pump down mode even when the door was open.
The problem ended up being too much water in the drip pan below the unit. There is a float in the drip pan that actuates the same limit switch as the internal overfilled float.
I had recently cleaned the incoming water filter and must have loosened the water line tube.
Nov 20, 2009 | Bosch SHV46C03 Built-in Dishwasher
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHX46A dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Apr 01, 2008 | Bosch 24 in. SHE56C05UC Stainless Steel...
Bosch sms 4012 dishwasher
hiya,
Can't solve this problem unfortunately but I however have been given a Bosch sms 4012 without the manual and was wondering if you could tell me how to make it go.
Mar 15, 2008 | Bosch Dishwashers
Bosch SHE43P05UC Builtin Dishwasher Logo
711 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
