Question about Air Tools & Compressors
I have a senco finishing gun. It works fine but then sometimes it want do nothing an then after I keep trying it starts working. Any help on what's wrong?
  • 98 Answers
After some use the glue on the nails builds up and needs to be cleaned up. try WD40 should help.
Posted on Oct 16, 2013
5 Suggested Answers
  • 24 Answers
SOURCE: Senco sn2 air leak around out top only when the trigger is pulled
There is a cracked seal on the firing valve. It looks like it cant be replaced but it can. Look in your parts breakdown .It seals the firing valve to the cylinder
Posted on Apr 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: do I need to oil this gun during use?
yes, squirt oil in the tool 2 times daily depending on use. do not oil the nails/pawl area, it only collects dirt. About 6 drops in the air fitting should be fine.
Posted on Nov 15, 2009
  • 142 Answers
SOURCE: i need a part for a Senco 325 nail gun. The only
it is the same bumper
Posted on Dec 08, 2009
jyackle5
  • 8197 Answers
SOURCE: Nut just above knurled depth
You do not need to wory about that nut. If you do want to change it you can learn how on the link below.
http://www.senco.com/Documents/Guides/FIP35_PC.pdf
Posted on Aug 26, 2011
I am using senco gas in a paslode 2nd fixing nail gun. Is the senco gas 'bad for' my gun in any way as i am having a few firing problems
You can use most gases in your gun, but paslode is the best that's why its more expensive. Try warming the gases in your pocket that sometimes helps.
Dec 17, 2014 | RTO Paslode 902000 IM250 Ii Cordless 16...
I have an older pro 18 serial number is 03c19425. It shoots with out pushing the safety in and not sinking nails. It leaves them about an 1/8 to 1/4 out. What do I do.
The Finish Pro 18 is a very good gun but I wouldn't spend more than $50 to fix it. You can get the newer FIP18mg for around $90 which includes a new warranty. If you really want to repair your gun:
Go to www.senco.com, click on the link 'Parts Charts/Specs/Manuals' at the top, scroll down to the Finish Pro 18 and open the parts guide. You are going to have to find out what parts of the safety element are broken or missing. As for the not driving nails all the way in, you have worn or broken o-rings inside the gun. The parts guide shows you need a Senco repair kit #YK0393. Senco no longer makes this kit but sometimes you can find them online at aftermarket retailers. Just Google or Bing 'Senco YK0393'. If you can't find one you can order all of the required parts from Senco but you have to order each one using part numbers from the parts guide.
Feb 16, 2011 | Senco Tools & Hardware - Others
Air tends to leak near trigger of my senco sls15 1/4" crown stapler . how can i stop it?
You have worn or broken o-rings/seals inside the gun. You need a Senco repair kit YK0393. Senco doesn't make them any more but there are still a few to be found on the internet. If you can't find one, go to the Senco webpage, find the parts breakdown for your gun and order all of the o-rings, seals and gaskets and rebuild your gun.
Feb 09, 2011 | Senco Finishpro 15 Finish Nailer & Sls15...
Finish Pro 32 is Leaking air out of the exhaust cap
You have worn or broked o-rings/seals inside the gun. The Finish Pro 32 is one of Senco's older guns and they no longer offer a repair kit for this gun. You have to go to a site like www.senco.com or www.ereplacementparts.com, find a breakdown of your gun and order each part you need. If you are going to rebuild the gun order all the o-rings/seals (Senco parts that start with LB) and any other parts that may be damaged like the piston stop, springs, etc. Lubricate the o-rings with light grease as you put them in and make sure to oil the gun regularly when you are using it to make your work last.
Jan 27, 2011 | Senco FINISHPRO32 ProSeries 16 Gauge...
My Senco SFN1 finish nailer will not shoot a nail. When the trigger is pulled air comes out but no nail is shot. Thanks,Steve L
Not sure about Senco but most have latch you can open to expose firing mechanism. Nail sometimes gets jammed and will not allow driver to fire or if not nail push driver ****** all the way back into gun then see if gun will fire.
Oct 25, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
I have an older model senco finish nailer that continuously blows air out the exhaust what is the problem?
probably a split or stuck o ring. You can go to Senco.com and download a breakdown and purchase a rebuild kit for this tool.
Mar 27, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
Gun will not drive pins flush with wood. Wood is
What is your air pressure setting. A finish nailer such as this usually requires 70 lbs to drive flush. Adjust air to this value and test fire in scrap. Keep adjusting air presure until nail drives flush.
Nov 23, 2009 | Senco 4N0001N Finishpro 11 23 Gauge Micro...
Apr 08, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
