Question about managemylife.com
My Kenmore top load washer..model#2600*010,2601*010...is stuck on sensor will not start a wash.I have checked for loose wires and hoses nothing was wrong with them nothing is clogged....what else might be wrong? Or should be checked?
  • 438 Answers
Is the device trying to fill with water ? it will not continue through its programmed cycles until the drum is full of water
If not than the device is waiting for water, Check the water fill valve with a continuity tester it should show continuity across the 2 contacts if the valve is OK than check the water level detecting device it will have a thin hose attached to it this could also be faulted or the tube to the device is plugged with soap residue and give a false full drum reading to the device, it could also be a faulty water levels selector switch.
Try this and let me know what you find
Best regards Falco
Posted on Oct 15, 2013
What does the code F35 mean when i start my machine it will start and turn for a few seconds and then it stops the code F35 comes on and the machine wont do nothing it still show all the light on but it...
The F35 indicates that the main control board detects a problem with the analog pressure sensor (water level pressure switch) in the washer. This component senses and controls water level in the washer. This failure could be caused by a pinched or broken air hose between the air trap at the bottom of the washer tub and the analog pressure sensor. It can also be caused by a clogged air trap or a failed analog pressure sensor. If you are able to unplug the washer and pull off the top panel, you can check for the probable cause of this failure.
To remove the top panel, remove the screws on the very back of the panel that secure it to the washer cabinet. Pull the top panel back slightly and then and off of the washer. It is on the side wall just behind the expansion control board. You can check the air pressure hose connection and the wire harness connection on this component.
This component costs around $99.This information was based on the general description of the washer model that you provided (Kenmore Elite front load washer). There are several different models of this washer.
Mar 24, 2011 | Whirlpool WFW9200S Front Load Washer
Why does my kenmore oasis washer 110.27042603 show f1 @ every start of load? what part do i need to replace to correct problem? please help!!!!
Customer has F1 Error Code. The control is sensing an error in the signal from the air pressure sensor circuit. CAUSE: CORRECTION: HE Top Load Washers Models: F1 Error Code WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T Serial Numbers: CT01 - CU52 There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure that the diagnosis is correct and the proper repair is completed. A) Air leaks in the air pressure (switch/sensor) hose. a. Inspect the hose for cracks, pin-holes or loose connection. b. Replace the hose and harness assembly (W10058730) if it is compromised. B) Moisture in the air pressure (switch/sensor) hose. a. Inspect the hose for evidence of water. b. Replace the hose and harness assembly (W10058730) if water is detected. C) Lint or flashing in the air dome hose connection port. a. Inspect the air dome hose connection port for lint or flashing. b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on the tub. D) The control needs to be replaced. a. Replace the control only after you have completed steps A - C above, and verified that there are no issues with the air pressure system.
Jan 04, 2011 | Kenmore Oasis 27042 Top Load Washer
Timer only works on heavy cycle not on normal model #11024632300
Could be a bad timer or loose contacts.
Unplug the washer.
Open the control console.
Remove the wire harness connector from the timer and re-insert it.
Also advance your timer manually 360 degrees around several times. This can cause stuck contacts to work correctly.
If this does not correct your problem you will need a new timer.
Feb 14, 2010 | Kenmore 24632 Top Load Washer
Describe your Kenmore 24032 \ 24036 Top Load
the tub.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
The above is from a service bulletin. I have also seen this problem caused by a loose electrical connection between the flowmeter and the control board. Try unplugging and reseating the plugs between them and look for any signs of corrosion and clean if any is found. Sorry for the trouble you are having and I hope this helped. Best wishes.
Sep 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore top load portable washer, model 110.42722200
i had same prob. at my daughters house, similar model. first time a hose popped off the top(i removed the lid), later i noticed leaks because my son in law was using oxy clean and it foamed over. my advice is, put machine on its side and look for loose/popped off hoses, dont use too much soap or additives, which will trick the water level sensor or just pour over that little drum
Jul 16, 2009 | Kenmore 2.1 cu. ft. Portable Top Load...
Kenmore Washer Top Load Series 60 won't drain
The water pump is a belt-driven device actuated by a clutch. Your problem could be:
1. Stuck pulley - break it loose and WD-40 it
2. Broken belt - replace
3. Bad clutch - call repair or replace
There is almost nothing that can go wrong in the pump itself. It's probably one of these three.
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Started a new load of wash and water never shut off flooding room
you can check for a broken/cracked/ dettached plastic hose leading from the back left side of tub to the pressure switch under the main console. usuall problem is it dry rots and cracks, or comes loose after shaking/vibrating,
Nov 15, 2008 | Kenmore 22422 Top Load Washer
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Nov 12, 2008 | Kenmore 22422 Top Load Washer
Kenmore top load washer machine
check that none of your hoses are blocked, by pulling the back cover off. If any of these hoses r blocked it will stop the washing machine from working same thing happened to me and thats how i fixed it
Jun 02, 2008 | Kenmore 80754 Top Load Stacked Washer /...
managemylife.com Logo
109 people viewed this question
Top managemylife.com Computers & Internet Experts
Steve
Paul Bade
Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
