Question about Garden
I need an owners manual for Cub Cadet chipper shredder vacuum Model #24A-061K710 114-217
buffalonyman
  • 1865 Answers
SOURCE: Can I print out the maintenace manual for Cub Cadet Mower
I need the serial number so that I can locate the manual
Posted on Jun 16, 2009
lester482529
  • 226 Answers
SOURCE: I need a diagram for the deck belt on my Cub Cadet
go to partstree.com put in your make &model #.then clickdeck assembly.hope this helps
Posted on Jul 19, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
  • 13 Answers
SOURCE: I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Posted on Apr 16, 2010
Fix4You
  • 32 Answers
SOURCE: how to replace the drive belt on a 2006 cub cadet
Use the link below to download the manual for free.
http://www.cubcadet.info/Manuels/2005/Tracteurs/LT1042-LT1045-LT1046-LT1050-Owner.pdf
Posted on Nov 14, 2010
Engine switch
The switch could be faulty as it should kill the engine in the off position.
It is possible that it is wired incorrectly.
Dec 03, 2013 | Cub Cadet 1.5 in. 173 cc Chipper Shredder...
Cub cadet chipper shredder starter coil is locked - will not pull
REMOVE THE SPARK PLUG. You now can safely take apart the unit to remove the covers over the chipper and shredder blades and remove the material stuck in the blades.
Aug 23, 2013 | Cub Cadet CS2210 - 2" 208cc Tow-Behind...
Owners manual for Troy Bilt Shredder Vac 47279
check this website..........brentchalmers.com
Jul 09, 2010 | Troy Bilt Walk Behind...
Need owners manual for 2001 yard machine chipper schredder model #24A464B131
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. (wchan@bushbros.com)
Mar 27, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
24a-020d700 won't start, new gas & replaced air filter
Hi
First you need to check for spark at the plug if you have spark remove plug put a tea spoon full of gas in the plug hole reinstall the plug and try to start. If it starts for a sec the carb or fuel line is clogged and needs to be cleaned.
Sam
Jan 02, 2010 | Yard Machines 24a 021h700 4.5 Horsepower...
Having trouble with Mower...what to do?
Clean out the carburetor float bowl and main jet. Sounds like dirt or moisture in it
Sep 12, 2009 | Yard Machines 24a 021h700 4.5 Horsepower...
Owner manaul
MTD manuals are here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
Apr 02, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Garden Logo
132 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
