Question about Staples SPL1524CP Strip-Cut Shredder
Can you put a trash bag in the Staples SPL1524CP model? My boss is concerned it will start a fire!?!?!?
Do i need to put my Recycled bottles in a trash bag then in my Blue Recycle Bin? Or can i just throw the Bottles in the bin?
Do NOT put your recycleables in a trash bag. Put them straight into the bin. It saves you a bag and saves someone at the recycle plant from having to remove it and throw it away.
Jan 04, 2017 | Green Living
Where can I get the 8.14 gal. waste bin for an unidentified office shredder?
Trash Cans & Recycling Bins ' Staples®
www.staples.com/Trash-Cans-Recycling-Bins/cat_CL141928
Staples Inc.Use trash cans and recycling bins to keep plastic drink bottles, loose papers, and snack wrappers .... simplehuman® Slim Step Trash Can, Plastic, 10.5 gal.
13 Gallon Trash Cans : Trash Cans & Recycle Bins - Walmart
www.walmart.com > ... > Trash Cans & Recycle Bins
Walmart
Jan 01, 2016 | Office Equipment & Supplies
What size bags does this shredder use?
Would you care to elaborate? Brand, model?
Here's how you can figure it for yourself, measure the size of the waste bin: length x width x height. Then divide by 1728, that will give you the amount in cubit feet. Then multiply by 7.48 (1 cubic foot = 7.48 gallons).
For example, my Fellowes measures 7.5"x16"x10.5"= 1260 cu in.
1260 / 1728 = 0.729 cu ft.
0.729 x 7.48 = ~ 5.5 gal.
If you looking to buy bags, check Staples website. They have all different sizes.
For the Royal I have in one of my bedrooms, I just buy a cheap brand of waste basket bags at the grocery store. Like them because they have a pull tie close and none of the little paper thingies liter the street when the trash truck comes.
Aug 25, 2014 | Office Equipment & Supplies
My powershot doesnt work seems like spring or some thing broke
Mine was stubborn right out of the box. Didn't want to "fire". Put a tiny drop of light machine oil where staples exit. You can also remove staples and do some swabbing around sliding parts with same oil and a QTip. Fixed mine. Just be sure you have right staples for your model. Bought my staples in the tool dept. at WalMart.
Nov 16, 2011 | Black & Decker 5700 Powershot Forward...
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 | Vacuums
Bag model for Eureka Mega Boss 4460 type E
The model 4460 is for a Victory model which uses Eureka Type AA bags
They can be found at http://www.totalvac.com/eureka_aa_bags.html
Jun 10, 2010 | Eureka Mega Boss 4460DT Vacuum
How do I open the swingline model 900xd
It took me and my boss wrestling with this mongo stapler for 15 minutes to figure it out! :0)
To open the front end, pull up on the handle while simultaneously pushing down on the small black lever on the front. This takes some firmness and be warned, if it's jammed with staples it's going to take some serious force to get it open - watch your fingers!!! I strongly suggest the minute you get a jam, open up the front and clear it. Don't continue to staple in hopes it will work or clear itself or you will have a build up of jammed staples making it almost impossible to open and clear. Also note that when you open up the front end the staples tend to shoot out so be careful.
To open the back end to load staples, push forward and up.
Hope this is of help :0)
Dec 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Where do i put the trash bag in the machine?
I have access to the service manual for this machine if it will help you.
Dec 03, 2009 | Philips Vacuums
Euerka Smart Boss upright
Price of Belt: $ 7.49 from www3.sears.com
Part No. 61110A
Price of Bag: $7.99 for a pack of 3.
Part No. 61115A or Eureka Bag Type RR
Estimated Repair Cost: $75-90 pending parts and labor rates
The likely possibility is that the belt was installed wrong. Without seeing the unit myself, I cannot say if the pulleys are mis-aligned. I will get back to you if I find any new information.
Mar 14, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Staples SPL1524CP Strip-Cut Shredder Logo
29 people viewed this question
Top Staples Office Equipment & Supplies Experts
 Bob Buchholz
Bob Buchholz
ray gallant
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
