Question about Troy Bilt 25HP VTwin Hydrostatic 50" Zero Turn Radius Mower
How do I replace drive belt on troybilt xp zero turn rider? Do I n0eed to drop the main drive pulley under the engine?
    Master:
  • 492 Answers
Check YouTube for a video
Posted on Oct 18, 2013
Is it possible to tighten a loose belt on my cub cadet RZT-54 ZERO TURN RIDER.model number 17AFCACK009
HI,
I assume you are reffering to the mower deck pulley...however, the belt that drives the two hydraulic motors work the same way as deck pulley system.
First, there is no manual adjustment on the pulley system. Rather there is a spring loaded pivot arm to which an idle pulley is fastened to. The spring pulls the pivot arm in such a way the it forces the idle pulley to keep the belt tight at all times. The same setup is used on the ground drive belt.
Sometimes these springs become disconnected or break so that no tension is placed on the belt to keep it tight.
Check the tensioner spring to ensure that it is connected properly and applying tension to the belt. Otherwise, you may have the incorrect belt installed, the belt is routed incorrectly or the belt may be stretched out and need replacing.
Here is a diagram to clarify, the spring is the dark black item;
Here is a link to a large diagram that is easier to read;
Lawn Mower Parts Small Engine Parts Much More PartsTree com Briggs MTD...
Jul 14, 2014 | Garden
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
I got a troybilt rider mower. I dont know anything about mowers. I got this from a neglected owner and the final thing that got him to sell. Was the battery charger was wrong and it blew the acid all over ...
There should be a second belt that goes from the engine to the transmission. This could either be slipping due to a mis-adjusted pulley or another bad belt.
May 18, 2014 | Garden
My riding lawn mower wont move when in gear the brake doesnt work either
have you checked the main drive belt or the gearbox drive belt? Most mowers built by MTD have a main drive belt that is run from the motor pulley to the rear end, then a shorter belt actually drives the gearbox. Mine is a Cub Cadet and you can usually get to the back belt by removing the battery and battery box. By using a piece of water pipe about 3 ft long you can move the spring loaded pulley and reattach the belt. MTD builds a large majority of the riders up to 25 hp. Ex. John Deere, Cub Cadet, Troybilt and many of the store brand riders. my Cub Cadet sometimes has a drive linkage pin to fall out and instead of stopping it goes faster. you didn't give the brand name of your mower so that would help.
Apr 28, 2014 | Garden
Will run but doesn't move
If it doesn't move at all; I would check the drive belt first, then the belt idler pulleys. Just make sure that no one has put the hydro units in bypass mode so they could move the mower without the engine running without your knowledge..
Feb 28, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
HAVE A TROYBILT RIDER AND IT KEEPS BREAKING THE EXTENSION SPRING. WHY
check your spindel bearings for being bad or idler pulley on top of deck
Jul 09, 2013 | Garden
I have a troybilt xp, and the self propel fontion
Does the drive shaft going to the wheels turn at all?
If it doesnt you may have a unsecured pulley on the engine.
If the shaft does turn when you engage the tranny your next stop is taking the wheels off and checking the wheel clutches. Sometimes called sprag clutches. They are probably both stuck in the unlocked position. You need to clean them up by removing all the greasy material covering them and putting them back together with just a few drops of light oil.
I hope this helps. Good luck and be careful!
Jul 28, 2010 | Troy Bilt 5.5hp Self Propelled Mower
The main drive belt on my 46'' rider came off and I can't figure out how it goes back on. i bought it used so no manual. The belt looks fine. there is the main drive pulley under the engine, a freewheeling...
best I can do is suggest going to your favorite search engine like google and type in the name of your mower and what it is you need and hit the enter button.. you will be surprised to find what your looking for...good luck
Apr 03, 2010 | Garden
Unable to find the Troybilt deck V belt that fits my 2002
If it's the belt that just runs on the deck and not the one that goes to the engine, it is a 954-0349
Jun 24, 2009 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Troy Bilt 25HP VTwin Hydrostatic 50" Zero Turn Radius Mower Logo
150 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
