Question about Sony KP-48S70 48" Rear Projection Television
Triple picture and purple bubble on big screen
Hi i have aq sony 53" rear projection tv model number kp-53xbr200 and it hase a triple picture in three colors and a purple buble in the top left corner what can i do to fix this problem
  • marksmonster Sep 17, 2008
    samsung hd 42" hcm 4215w purple line down middle screen. appears to have scracth on green lens, after removing top lens?do i need a lens or crt tube?
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
triple
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your contriple picture and purple bubble on big screen - 2c07611.pngips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
578ba6c.jpg TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 28, 2009
    Genius:
  • 1,139 Answers
You may have to degauss your CRTs. Somehow your CRTs have become magnetized and that is what is causing the purple bubble, now as far as the three color pictures, that might be a sign of a convergence problem. for that you may have to put your set into service mode and set the convergence. But first try to degauss the CRTs with a degaussing coil (they have specials on ebay). You will need your owners manual, the remote control, and some patience.
Posted on Sep 26, 2007
SOURCE:
The tv looks like the old tvs with the contrast controll how do you adjust a projection tv
Exactly as the old TV's. There is three tubes producing the picture and the technology is just the same. If you cannot find your instruction booklet, log onto Sony's web site and download it.
Hope this helps.
Nov 12, 2010 | Sony KP-53XBR200 53" Rear Projection...
Fuzzy picture
have you taken off the screen and tried to clean the lens as well as the mirrors inside the set?
May 04, 2010 | Sony KP-53XBR200 53" Rear Projection...
The screen looks faded. The colors are right, but
take off the front of the set, and clean the lens as well as the mirrors inside the tv set
Techman
Dec 14, 2009 | Sony KP-53XBR200 53" Rear Projection...
My sony tv stars blinking 5 times in a row, then the picture goes black for a second comes back then goes black again and it keeps doing it non stop
tv has a blanking picture mute circuit. adjust the screen controls which are located behind the speaker grill in front of set. there will be a access panel to unscrew in center and then you will see a black 4 inch square box with 6 physical knobs. 3 control screen the other 3 controls focus for red, green, blue. turn them down and slowly start turning them up. fixed.
Nov 11, 2009 | Sony KP-53XBR200 53" Rear Projection...
How do I stop from getting double pictures on my KP-53XBR200 53 in? And Stop the color green from going of center with the rest of the other colors?
Could be a convergence adjustment from your remote under MENU. (This can be done by you)
Could be a problem in the convergence circuitry. (This can be done a TV tech only)
N Sabre
Nov 07, 2009 | Sony KP-53XBR200 53" Rear Projection...
SONY rear projection TV - Whites have started looking "snowy"
This is your Picture tubes getting very weak.( low in emission ) You have three in there and I guarantee they are no longer available so I would start thinking about investing in a new set, but use that one until you can't stand it anymore.
May 28, 2009 | Sony KP-53XBR200 53" Rear Projection...
Changing Bulb In Big Screen
That model Sony doesnt have a bulb it has three picture tubes cost about 250 -300 each and need to be properly aligned when replaced
Mar 04, 2009 | Sony KP-53HS30 53" Rear Projection...
SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Kp-53xbr200 SONY video shuts off but sound stays on
Sounds like a bad solder connection. When you lose video, does the on screen display still work, and if so how about your picture in picture? If no OSD or PIP works then you may be loosing your High Voltage to the picture tubes. Some circuit board assemblies are no longer available from Sony for this model so you may be out of luck if the problem is more than a bad connection.
Jan 28, 2007 | Sony KP-53XBR200 53" Rear Projection...
Sony KP-48S70 48" Rear Projection Television Logo
501 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
