Question about SCOSCHE Aa1574b 99-03 Acura Tl & 01-03 Cl Pocket Kit
Heater in 2003 acura tl is blowing cold air - SCOSCHE Aa1574b 99-03 Acura Tl & 01-03 Cl Pocket Kit
  • 133 Answers
Check the coolant level,if its low there will not be enough coolant to enter in to the heater radiator,check for leaks too
Posted on Oct 15, 2013
2000 acura TL my air conditioner or heater doesn't blow at all and its not a fuse
built into the motor is a resistor pack and this i suspect is your problem
Oct 19, 2012 | 2000 Acura TL
The heat, air, defrost functions do not blow any air. Just stopped blowing. I have a 2003 Acura TL.
try checking the fuse if that is not the problem then replace the blower motor resistor located on the heater box neer the blower motor on the passanger side under the dash
Mar 05, 2010 | 2000 Acura TL
Air cinditioning blowing from cold to hot air
need to check ac fan or fans ,are they working? if not check fuses and fan relays,,,,,and fans (hot wire the fan to see if it/they work
Jul 05, 2009 | 2000 Acura TL
Air Conditioner blower no longer blows
verify that there is power to the blower motor and that a fuse is just not blown.
if the fuse is good and there is power to the motor you will need to replace the blower motor.
Jun 12, 2009 | 2000 Acura TL
2003 Acura TL Heater Control
Hi,welcome to fix ya.
there is a motor under the dash on the passenger side called the "air mix motor" by acura that goes out on these and causes this it is just under the carpet under the radio .you can reach it from the passenger side . change this and you adjustment will return
Mar 31, 2009 | 2004 Acura TL
1996 Acura TL Heater blows cold air when stopped
the heater core could be clogged you might again check your coolant level just to be sure its full
Jan 24, 2009 | 1994 Acura Legend
Sticky valve
first check to see if theres even enough coolant in the car first if ther is get a buddy to turn the temp to hot then cold from inside the car while you watch the heater control valve it sits almost directly on the fire wall it is connected in line on the inlet heater hose and has a cable connected to it see if the cable moves when your friend moves the control knob if it moves your problem could be in the blend door motor or control head if the valve is the problem it is pretty easy to replace just take your time to bleed the cooling system of air after the repair
Dec 31, 2008 | 1999 Acura TL
2003 Acura TL TypeS - heat and air not working
it's a wire from under the dash it usually burns out after awhile,i had the same problem email me at veron@sprint.blackberry.net for more info on the wire i forgot the name for it.
Dec 18, 2008 | 2000 Acura TL
SCOSCHE Aa1574b 99-03 Acura Tl & 01-03 Cl Pocket Kit Logo
70 people viewed this question
Top SCOSCHE Car Audio & Video Experts
ray gallant
Your Consultant
Jerry Kramer
Jerry Kramer
Are you a SCOSCHE Car Audio and Video Expert? Answer questions, earn points and help others
