Question about Honda Electrical Supplies
EG4000cl honda generator starts up runs for a little bit then dies , oil level is good and i unplugged the oil shut off wire and it still dies , it dont seem to me to be a fuel issue because it starts right back up and runs fine for 30 sec's or so then just shuts off...any advice?
deme-tri
  • 90 Answers
SOURCE: New NorthStar generator with Honda GX620 runs only a few seconds.
caborator needs cleaning
Posted on Aug 02, 2009
  • 77 Answers
SOURCE: onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Posted on Aug 10, 2009
  • 905 Answers
SOURCE: Onan Marquis Gold 5500 on
A1 controller could be suspect, http://www.flightsystems.com/ can get you going with board cheaper than OEM, last longer too.
Does the generator shut down immediately after you let go of the start switch? If so, you are looking at oil pressure / level fault. Check oil level and sending unit. If generator continues to run for a few seconds and then shuts down, that is due to no or low AC voltage being produced and shutdown occurs. Shutdown for AC usually indicates an open winding or damaged voltage regulator.
Posted on Aug 25, 2009
protek480
  • 1714 Answers
SOURCE: The generator starts up then dies?
Check the oil pressure switch. It will shout you down like that if it doesn't sense oil pressure.
Posted on Oct 01, 2009
dmftrucker
  • 1922 Answers
SOURCE: Engine starts and runs fine for about a minute
try to clean out the carb first with auto parts carb cleaner, then you may need to buy a totally new carb for the unit, as this company will NOT sell parts for these carbs due to the carb setting is sealed & has to stay at a set level for voltage output and setting
Posted on Nov 05, 2009
Onan 6.5 rv gen set starts buts dies when start button is released
First check the oil. If the oil level is low it will not run. If the oil level is good the generator may not be producing power and you will need to troubleshoot the generator.
Oct 27, 2016 | Electrical Supplies
Generator won't start anymore, barely pushes any power the one time it did.
I would take it to a Honda repair shop and let them check it over before throwing more money down the rat hole .
Jun 18, 2015 | Honda EU3000iS Inverter Generator
The generator shuts off after 30 minutes with an oil level alert but oil level if full
Your oil level sensor is bad. It needs to be replaced. If you unplug the wire leads to the sensor you may get the generator to run, but you'll have no low oil level/pressure protection. The oil level sensor is on the engine crankcase usually near the oil level dipstick. You'll likely see a small sensor with a couple of wires attached to it. To replace it, you'll need to drain your engine crankcase before removing the sensor.
Apr 06, 2014 | Kipor RV Generator Sinemaster IG3000
Honda eu3000is shuts off suddenly?
There are two likely causes.
Honda generators have an oil level sensor which kills the ignition when the oil level drops too low. Check the oil, and if it shows there is enough, temporarily disconnect the wire going to the level sensor switch--usually a black wire with a white stripe--and see if the problem goes away. Oil level switches can fail intermittently, causing engines to die after they run for a while.
Exhaust valves with an insufficient gap can also cause your problem. A cold engine will start and run but as soon as it warms up, it will die. When the engine cools down, the engine will start easily, warm up and die again. Check the valve gaps when cold and adjust to meet the specification, usually 0.003".
Feb 03, 2014 | Electrical Supplies
Honda GX160 firepump runs good than dies starts first pull after and repeats
Check that the fuel tank is venting properly, sounds as though the tank is not venting therefore creating a vacuum that the carburetor cannot over come. Try running the engine with the fuel cap loose to see if that alows the engine to continue to run.
Dec 16, 2012 | 5.5hp 6:1 Gear Ratio GX160 Engine
Cranks fine then dies out
check for spark when it cuts off also check the oil level some have a low oil shut off also dry and run it with the gas cap loose to see if the vent is plugged
Sep 01, 2012 | Generac 5622 portable generator,5000 rated...
Generator runs for about 10 minutes and then stops like it is running out of fuel. 5500 NorthStar with Honda motor. Waned fuel tank and lines, had carb. Rebuilt and cleaned all out with carburetor cleaner....
It appears you have eliminated all of the fuel related issues. That would leave the generatoor safety circuits as a possible reason for the unit shutting down.
The Low Oil Level Sensor is the major reason that generators shut down when your sure there is not a fuel supply problem. Make sure the unit is fully servied with OIL. If the problem persists disconnect ONE wire from the low oil level sensor and see if the problem persists. If you still have the problem inspect the black or green wire from the Start run switch all the way to the Air shroud on the engine looking for signs of chaffing.
If you can not find anything then you will have to re-focus your attention on the fuel system once again. If you have a solenoid on the base of the carb.. the solenoid can be WEAK and stop remaining open once hot. This will cause the engine to lean out and die.
You should also check fuel flow to the carb. The flow should fill a spary paint can lid in under 10 seconds to the point your worried about it overflowing. Most honda engines have a metal sediment bowl under the fuel selector. Remove the sediment bowl and dump the contents. Check fuel flow again.
- Carb. With the float bowl removed fuel selector ON check fuel flow again by holding a spray paint can lid under the float. It must fill up in about 10 seconds to the point your worried about over-filling the lid. If you do not have a good flow rate here the float needle float needle rubber seat and the fuel manifold are the prime suspects.
I know this generator has the Honda GX270 engine. Some have solenoids (Item 49 this link)
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE,%20JPN,%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CARBURETOR%20(2)/parts.html
^- No details!
Honda engines by model and VIN can be found here:
http://www.boats.net/parts/search/Honda/Engine/0/parts.html
At this time I think the low oil level sensor (sending uint) may be the culprit causing your problem.
Item 2 this link:
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE%2C%20JPN%2C%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CYLINDER/parts.html
Thanks for choosing FixYa,
Kelly
Sep 16, 2011 | Electrical Supplies
Honda eb3800x will not start. I started and ran it in June 2010 with no problem. Will not start today 9/2/2010. Checked oil, checked spark plug, drained all gas and put new gas. Carb getting fuel....
the worst thing for generator and compressors are to sit up. when you do sit them up put stabil in the gas. run it and then run the gas out of the carburator. now, make sure the gas in the tank is good and has no water or trash. check the fuel line that it is in good conditon and not plugged. pull the carberator and clean varnish out and clean jets. soak it over nite in varsol or parts cleaner. check to see if you have a low oil shut off. oil level must be correct. check your exhaust to make sure it isn't plugged. some have a little screen that get coated with carbon and won't let it exhaust.( fuel in, spark, exhaust out)
Sep 02, 2010 | Electrical Supplies
How can I shut my Honda eu1000i off from inside the cabin?
You should not have to cut any wires to install a remote kill switch. Most honda engines have an oil alert what will cut ignition if oil level is low. The switch actually shorts the itnition to ground just like the on / kill switch. Just unplug oil alert wire from harness and add a homemade connector with second lead and connect another wire to ground/frame of generator engine. When you short these two wires together it should kill engine. Solder these two wires to a female connector (Radio Shack) and just leave inside generator when you want remote switch. Attach switch to leads of desired length of male connector to mate with female connector at generator. Good Luck.
Jul 10, 2010 | Honda Electrical Supplies
Electrical Supplies Logo
76 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
