RECO is blinking on the thermostat - Heating & Cooling
  • 400 Answers
The thermostat is in recovery. It automatically senses how long it takes to heat your home so that when you schedule it to turn on at say 6AM, it will turn on in time to reach the set temperature by 6AM.
Posted on Oct 22, 2013
What does RECO mean when I hit my compos function on my pathfinder? Everything else works. Cannot find my manual that came with the watch. Thanks much and sorry to bother you. John
I believe the RECO refers to the NIST time signal that the watch receives at about 2-3am to reset the time. If you're not in North America then you can somehow set the NIST signal to another signal in JAPAN or GERMANY although those signal may be WRONG as those signals are based on sand-filled hour-glass bottles in those countries.
Aug 09, 2017 | The Watches
Auto transmission not working
no spend your money on a new car
Oct 03, 2012 | 1997 Hyundai Sonata
HUnter thermostat reading RECO, Not cooling off house only blowing air.
Press & hold the HOLD button down to manually turn off the RECO error. This can happen when your unit goes into PS Mode.
May 22, 2010 | Heating & Cooling
Blinking re co on thermostat
It means that you are going into from one program to another program.
Jul 15, 2009 | Hunter Fan Company 5/1/1 Programmable...
Freezer and frige got power but dial wont work
It sounds like possibly your thermostat (dial) is broken. You could probably find a compatible thermostat at RECO or TECSA or any refrigeration spares shop. Makes sure you have unplugged the fridge, then remove the covers over the dial, either take a snapshot with a camera of the wiring side of things so that you can refit them correctly. Take the thermostat with you and the shop can confirm that they can supply the same type or a compatible. Be sure to let them check that the connections on the compatible (even if they look like they are in the same position) have the same function as the original.
Hope this works for you. Cheers Shane.
Mar 04, 2009 | Samsung Refrigerators
93 ford probe jerks when going into 2nd
Don't know if this will be of any help, but these cars have the same auto trans as the Mada 626s of the same age and they are a problematic transmission. They tend to blow up. Gerking could just mean it needs a service. ie: low fluid levels or 'worn out' fluid. It could also be an early sign of bigger problems.
We ended up selling our mazda because of the transmission. around $1800 to replace with reco but many people reporting reco trans failing within 2 yrs anyway.
Feb 05, 2009 | 1993 Ford Probe
Hunter thermostat need manual
Hi
u can fine your manual here...
http://www.hunterfanhq.com/hiw-prod/orderinv/frames/ps_frame.htm
Gary
Feb 28, 2008 | Computers & Internet
Error Message RE CO on Indiglo
Auto recovery – allows heating and cooling systems
to gradually recover from an energy-saving setpoint
temperature to a comfort setpoint temperature. Auto recovery
calculates the time needed to adjust the temperature to
the next program setting. When the thermostat is in Auto
Recovery mode, the display will flash alternating messages of
RECO and the time. Auto Recovery can be disabled by sliding
the recovery switch on the back of the circuit board to the
disable position.
(Auto Recovery will not operate if Permanent or Temporary holds
are on.)
Press Hold/Return during the Auto Recovery process to
manually cancel the recovery.
Jan 05, 2008 | Hunter Fan Company 5/1/1 Programmable...
How do i stop the filter message blinking?
go to www.honeywell.com, there they have a search engine. Put in your model number of the thermostat and look for the users manual.
Dec 27, 2007 | Honeywell Programmable Thermostat Heater
How do I operate the RLV430 Thermostat, I need some guidance
How do I set the tempature when the time is blinking and it never blinked and when set the temp it all 0 out
Dec 11, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
