SOURCE: I have a JVC L-A11 turntable. I cannot get the
I just had my L-A11 in to 'the needle doctor' (Jerry Raskin's shop in dinkytown, Minneapolis) We had the same problem with the platter.
After pulling (hard) to no effect on the platter - using the holes near the spindle and pushing simultaneously on the spindle. The tech next got out a small hammer, and while pulling on those same holes in the platter, he gave it a sharp 'whack' on the spindle with the hammer, and it came right off (the platter). I would have been too feint of heart to do it, but it worked great.
SOURCE: How do I change a drive belt on my JVC L-A11
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
