Question about Mayline Group Futur-Matic Drafting Table 8694B by Mayline
My Mayline Futur-Matic electric lift drafting table does not move up and down- only the tilt function works.
What brand of drafting table should I buy? What is the best type?
Alvin tables are a great starter with simple, inexpensive tables. Hann has fancier tables with lots of features. Mayline tables will last forever, while SMI and Safco make solid tables. For more information look here: http://www.squidoo.com/best-brands-of-drafting-tables
Jan 07, 2013 | Furniture
Should I buy an Alvin drafting table?
These tables are great because they are inexpensive and light. I chose this company because you can move the top board to different positions. However, I am an amateur artist so if you are a professional, maybe you should invest in a higher end table. These tables are built well but are smaller than others and come with less special features. This is great for me because I don't want any features. Also my apartment is really small so I got a great folding up one.
As a student, should I buy a drafting table?
I would say hold off. Drafting tables are not so common anymore. People who used to use them now use computer programs. Also, they are expensive for a student. However, you definitely need a table to work at. Most people find it easier to work with a slightly slanted surface so you may want a small drawing board as well.
Jan 03, 2013 | Furniture
Why are drafting tables made out of steel?
A. Most modern drafting tables are made from steel because steel is really strong, but also portable. Old tables made from wood were really strong but difficult to transport or move around. To make the table even easier to transport, the surface is attached with screws that can be unscrewed.
How can I tell if an old table I inherited is a writing table or a drafting table?
These two tables usually look very similar. If the drafting table was at a flat setting with the height set at regular desk height (maybe 74 cm) then it looks just like a writing table. The way to tell if it's a drafting table is if there is an edge on one of the sides. The edge was used to stop things from sliding off the table when the table was at an angle and it would sometimes hold writing tools.
What is a drafting table?
A drafting table is a multipurpose desk, usually made out of strong wood or metal. It is tilted towards the worker at a slight angle and is used typically by architects to sketch or plan blueprints.
May 29, 2012 | Furniture
Cold air from outside enters the kitchen through the down draft vent.
its would be best to install a damper
whether auto matic
or manuely operated
this is a common problem for the down draft
ive seen some people install things similar
to dryer vent louvers,
but check you exhaust area and still if you can block direct draft
but dont block it so that it cannot exhaust properly
Oct 11, 2009 | Jenn-Air JED8430 Electric Cooktop
Mayline Group Futur-Matic Drafting Table 8694B by Mayline Logo
782 people viewed this question
Top Mayline Group Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Mayline Group Furniture Expert? Answer questions, earn points and help others
