Question about Vehicle Parts & Accessories
Whats wrong with my car?!
Has been making this noise for over two months getting louder every now and then....auto body specialist said it might be exhaust cap. I would like to try to repair it myself. noise is louder with acceleration, quiter while idling.
    Problem Solver:
  • 5 Answers
How about a spun bearing
Posted on Aug 12, 2014
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 25 Answers
I agree with RJ Keck before deciding on fixing it yourself you first have to find the problem most of the time it is easier and cheaper in the long run to just take it in to a muffler shop and have them do it as it may need specialty tools such as impact air tools or even welding or cutting torch.. Some things are best left for the professionals to fix less headaches .. Good Luck
Posted on Jun 14, 2014
  • darryl Jun 29, 2014
    sounds like exhaust flange gasket .
    Novelist:
    Scholar:
  • 166 Answers
Obviously an exhaust leak, but you'll never find it by walking around the outside of the car. Why didn't you at least open the hood and trace the location of the sound that way?
Possibilities:
Cracked exhaust manifold and/or blown gaskets.
Rotted EGR tube (if equipped).
Loose or damaged front exhaust pipe and/or catalytic converter.
Posted on Apr 15, 2014
    President:
  • 1,082 Answers
First thing I would do is take it to an exhaust pipe shop. Almost every one of them will inspect it for free. possible rotted hole in exhaust front pipe. Do you get any exhaust smell in car esp. when sitting idle?
Posted on Oct 15, 2013
  • tace899
    tace899 Jul 26, 2014
    All good comments. Don't even try to repair yourself, the exhaust repair shops are far cheaper than you may think, and much more reliable unless you really have a hankering to do the job over and over again.
The power steering pump level is fine but making a wining noise when turning sometimes it's louder than what it is now !
check condition and tension of drive belt. The noise may be from failing relief valves in the system so have it checked out by an accredited steering specialist shop.
Jul 18, 2014 | Cars & Trucks
Strange noise in kenwood machine
It's gonna be the generator! When you hear this noise it's deffinately the generator
Nov 29, 2017 | Food Mixers
I don't know what could be wrong with my truck, when I was driving it sounded like my 4wd was stuck in a gear it was making a winding noise when I turned then it got louder as I tried to drive and sounded...
get it checkd by a 4weel specialist-cud be the rear or front diff or other parts--make sure fluid level is correct in both--library has mech manuals for ur model showing maintenance details for transfer case
Sep 17, 2013 | Cars & Trucks
1996 Ford Explorer front end makes noises after putting it in 4wd lo and red lining the engine, whats wrong with it?
You have to be in park or be in drive or moving slowly to
engage 4 wd
You can not have the trans in neutral to use 4wd or have the
transfer in neutral to shift trans
Either combo you grind gears in trans or transfer
Dec 12, 2012 | 1996 Ford Explorer
Saturn making a whining noise that gets louder when you press on the accelerator
Sounds like a bearing is on its way out in the drive belt system, could be the alternator, idlers, a/c if fitted, water pump.
Disconnect drive belt and spin all pulleys, and you will feel if one is loose, tight or making a noise it shouldn't.
Feb 26, 2018 | 1996 Saturn SW
The freezer sounds louder than normal, where the icemaker is. Turned icemake off but still louder. The icemaker, water and freezer still seem to be working fine.
There are only two other parts in the freezer that can make noisei if your icemaker is off. The evaporator fan motor makes noise when ice builds up around it, and the blades start hitting the ice. It also makes noise when the bearings start to fail on the motor. Rarely, the evaporator will make noise when the freon is pumped through it, we will get all kinds of strange noises. This is not a problem usually as long as your termperatures are fine. To check these items out, you will have to remove the icemaker and the back inside panel in the freezer. With it off, you can pinpoint where the noise is coming from. If it is a bad evaporator fan motor, replace it. Good Luck, Appliance Specialists
Jan 21, 2010 | Freezers
1996 saturn sl1 stick
take the wheel and drum off the back and check that the shoes are not worn out on the edges..what happens is the end wears off first but as pressure is applied the shoe moves to where there is some pad left..severe brake dust can do it too. get the brakes checked as soon as you can.to clean and adjust the rear brakes is not that expensive.
Jun 12, 2009 | 1992 Saturn SL1
1997 960 volvo.think? auto tranny pump makes whinny noise cold.
Your transmission is going to fail sooner or later, the whining noise you hear is the the clutch packs in the transmission going out.
Mar 26, 2009 | 1996 Volvo 960
Central a/c
check to make sure that the kids didn't change any other settings. Is the themostat still set for cold not hot? Also check the temp setting. Hope this helps.
Sep 11, 2008 | Heating & Cooling
Vehicle Parts & Accessories Logo
104 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
