Question about Mitsubishi L75A91 75 in. LaserVue HDTV
Color cycles. Will darken with a green tint, then ramp back up (3 or 4 steps) to normal color. Happens every six seconds or so.
2 Suggested Answers
  • 8457 Answers
SOURCE: green tint to picture; checked
Pictures still have colors shadows mixed into the tv picture wright?Yes?Tv still have and causes by convergence board as a problems.
Posted on Aug 13, 2011
67" Samsung DLP. Last night it started flicker to a green tint. Back to normal then green tint. Now it's completely a green tint. Still has picture and voice but green tint and not bright like before.
In those sets there is what they call color wheel and it could be on its way out it sounds like its stuck.or not working prop in any case you need to bring it in for service place
Mar 26, 2013 | Televison & Video
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
My LG flatscreen image emits an intermittent green tint and then reverts back to normal colors.
Sep 09, 2010 | LG 42LC2D 42 in. LCD HDTV
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
Samsung HCN2446W -- Yellow/Greenish tint all over screen
That model should be HCN4226W, right? Because the other don't come-up. Sounds like the mirror may have moved. It's mounted on the upper part of the back of the T.V. Should be flat against the back. Check that. Then see if all 3 tubes are lighting up. Also possable the fluid leaked out.....but not likely. These sets are fairly robust. Do you remember jarring it in the drive home?? Did you have it laying down when you moved it?
Dec 14, 2008 | Philips Magnavox 51MP392H Rear Projection...
KV-32FS120 makes a loud noise and green tint when turned on
Loud noise is possibly made by Degausing Coil to demagnetize picture tube and its normal.
Green tint shows picture tube is bit weak in electron emission due to its age and takes time to present good white balance result (good colors)
Sep 11, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Color sudden change
Good day.
Your unit is still worth. It may be a caused of loose contacts along the circuitry. It can be remedied by resoldering the terminals particularly the chroma section and the crt circuit.
chris
Mar 25, 2008 | Toshiba 36A61 36" TV
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Darkening
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Dec 01, 2007 | Hitachi 53SWX01W 53" Rear Projection...
Mitsubishi L75A91 75 in. LaserVue HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
