RCA XL 100 f19207bc menu button wont work
Menu button won't work I have and rca xl 100 model#f19207bc I dont have the remote for it I'm trying to change the brightness settings with the menu but when i press the menu button nothing happens. How do i fix this?
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
The front panel control buttons should be checked. Contact any service technician.
Posted on Oct 16, 2013
  • 119 Answers
SOURCE: FPA Lock
After doing a little research, it looke like the front panel lock , can only be removed from the parental control menu using your remote. If your universal remote does not get you into the menu, see if you can borrow a friends rca remote long enough to get you into your menu & remove the fpa.
Posted on Nov 03, 2006
  • 3 Answers
SOURCE: whana change my sanyo tv to input to play games?
you need a sanyo remote with input button - can buy from www.sanyo.com
Posted on Dec 29, 2007
  • 84 Answers
SOURCE: ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Posted on Jan 28, 2008
SOURCE: I can't select TV/Video input on the menu
Prueba poniendo canal 00 en el tv varios modelos de rca entran en modo de auxiliar en este canal.
Posted on Mar 12, 2008
  • 905 Answers
SOURCE: Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Posted on Oct 06, 2008
RCA XL 100 Commercial Skip TV
Only thing I can think of here is to get a Universal remote, then try these pins to Sync your TV with URM:
RCA - 000,003,004,005,007,009,011,015,048,082,092,094,
096,098,101,102,103,107,113,125,129,067,179,187,188,191,194
May not work 100%, depending on remote functions.
Instead of just buying any, you could maybe borrow one from a friend first of all.
Oct 11, 2017 | Televison & Video
My tv has no remote & now the menu button is no longer working how can i use it?
Contact any experienced service technician to get it repaired.
Aug 29, 2012 | RCA F19207BC TV
Accidently pressed the FDA button on my RCA TV and now its locked and wont turn on and i dont have a remote to it
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Jun 19, 2012 | RCA Televison & Video
My rca xl 100 remote will not work. I have changed the batteries multiple times. I was just wonder if i could buy a new rca remote and be able to have it work on my tv?
Yes,, you can easily purchase a new remote and have it work on that TV. In the packaging for the new remote you will find a piece of paper that contains the necessary remote codes for your TV. Follow the instructions provided with the remote and you are all set!
May 19, 2011 | RCA E13309 13-Inch Diagonal XL-100¿...
Tv is locked and wont turn on. i have no remote
Hello
If RCA tv has locked accedently and you haven't its original remote handset it is almost impossible to unlock it. Just try to get its original remote control from any of your friends or relatives who owns the same model of RCA set, borrow it from them for just unlock your set and try the following tricks. One amoung them will surely unlock your RCA.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
OK.
May 15, 2011 | RCA 24F512T 24" TV
My channels were scanning them selves and now the tv is locked and i dont have the right remote for it
Hello
Without orginal remote control, it will be very difficult to unlock your RCA tv. If you can gather a original remote from your friends or realatives who own the same model of tv, just borrow from them and try the following methods. One amoung them will surely unlock your RCA.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET. OK.
Apr 18, 2011 | RCA TruFlat 27F520T 27" TV
Chanells 50 and Up "Erased" how to Undo that
one is to go to menu and auto search the channels. but if your state is now digital programming then you need a convertor box to get local stations.
Feb 23, 2010 | RCA E13309 13-Inch Diagonal XL-100 Color...
My citizen tv is locked and i dont have the remote to unlock it is there a way to do it manually
Hold menu button +power+volume up you will go into service mode. Scroll down to see if you can find the reset which will reset the tv to factory setting erasing the password. I never had to do this it might work.
Jun 30, 2009 | RCA E13309 13-Inch Diagonal XL-100¿...
Change my rca xl 100 to it video input without a remote
ye a tech can do that.he'll make a extension of the video input at rear.or you can buy a switchbox for that.
May 20, 2009 | RCA E13309 13-Inch Diagonal XL-100 Color...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
