Question about Nuova Simonelli Premier Maxi Espresso Machine
Machine not making steam
All power on no steam
    President:
  • 1,618 Answers
Remove the right side panel and check the reset on thermostat(make sure there is water in the boiler before pressing reset).
Posted on May 15, 2009
Doesn't make enough steam
This usually happens when the machine needs descaling.Then we have more water than steam.
Mar 30, 2014 | Saeco Aroma Espresso Machine
I have two machines : Machine 1: I think the
Hi
Machine 2 is the steam manifold leaking. You have to remove the hose clip in the back of the steam manifold. Remove the hose. Grab the trough in the back and pull up to expose the manifold. It will push out the front. If its white is very old, and if its black its a newer one. If its metal it is priobably the O-rings just need to be replaced. I still have the white one in my machine, because I cool the manifold off after using and that won't let it crack from the high heat after steaming. That is what causes them to crack.
Machine one, I would check under the red boot covers by the boiler for a bulge in the hoses. That is usually where they rupture. Make the new hose(tube) a little longer to prevent this from happening again.
Apr 24, 2011 | Saeco Incanto Classic Espresso Machine
Steam wand leaks and no pressure.
Ok, remove the right side panel, you will see a red switch connected to the element by a metal coil, make sure power is off and unplugged, then press in red switch, you should hear a click, then open the steam wand and plug machine in and turn on, wait until you see small spurts of steam from wand before closing.
Jun 21, 2010 | Rancilio S24 Espresso Machine
ESTRO VAPORE / Thermostats verification ?
Using an ohms meter, disconnect one of the leads and check the reading across the terminals. Make sure power is off when checking resistance.
May 01, 2010 | Saeco VIA Venezia
Gets no steam
If you can make coffee and the coffee is hot that means the machine works fine and the only problem you have the tube nozzle clogged. So first switch of the machine a turn the knob to off position. Remove the steam nozzle cover and with the use of a needle or steel thin wire insert it to steam pipe all the way in so to make at least a small opening. Try again to work the machine and if you have atleast some steam continue use the steam so any dirt will spit out. The dirt might be dry milk or evn some big parts of scale which have been unstuck from machine during descaling and they have not desolve so to come out from the pipe. So the next time you will make descaling try to leave the machine with descale solution more time inside the machine before rensing.
Good luck
Please remeber to vote for this answer
Mar 13, 2010 | Saeco Incanto Classic Espresso Machine
Espresso machine not steaming
If the machine heats up for coffee, then the steam wand tips are probably blocked. Use a paper clip or needle to clear out the holes at the end of the steam wand.
Jul 03, 2009 | Coffee Makers & Espresso Machines
No Steam, No Coffee!
The steam boiler, might be damaged, or the main board is not sending power to the steam boiler. Open machine and check resistance on steam boiler elements.
Apr 18, 2009 | Gaggia Syncrony Logic 74884 Espresso...
STEAM PROBLEM
Does the steam itself smell, or just the milk. If yes on the steam run the descale again. If no on steam then check the perfect cream wand the black plastic arm connected to the steam wand, dissamble and clean, make sure all the holes are clear.
Mar 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Machine will turn on but that is it
The light 20 is power control light, 26 light if any problems are indicated on the machine and should only light if there are any trouble with the machine. 22 should light when the temperature is right.
Try to open the steam knob and make a cup of water.
Apr 04, 2008 | Saeco Vienna SuperAutomatica Coffee...
No steam, just hot water.
The steam wand has to be removed to be cleaned properly. Unfortunately, this procedure is not outlined in the manual. Just cleaning the wand on the outside or using a clip to clean the tip is not enough.
The other end of steam wand where it connects to the pressuring cabin actually swivels around a fitting. It is this fitting that you need to thoroughly clean. Years of using the machine can cause calcification around this fitting.
If you look under this end of hte steam wand, you should see a philllip-headed screw. Before you loosen this screw, you have to remove the grey trim so that the entire wand can be remove.
Once the entire wand is removed, what I just described will be much clearer.
Nov 10, 2007 | Breville ESP8XL Espresso Machine
Open Questions:
See all Nuova Simonelli Premier Maxi Espresso Machine Questions
Nuova Simonelli Premier Maxi Espresso Machine Logo
161 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
