Question about Exercise & Fitness
Sole treadmill displays LS1 error as soon as I press start.
    Top Expert:
  • 12,223 Answers
Follow this steps and fix it. God bless you
Power Supply An inadequate power supply limits a Sole treadmill's speed to 7 mph, even though the display may say it is going faster. Plug the treadmill directly into an outlet without using an extension cord for best performance. If this is not possible, Sole recommends using a short 16 gauge minimum cord.
Belt Too Tight A walking belt that is too loose will slip and one that is too tight runs slowly. Adjust the tension by inserting a 6 mm Allen wrench into the hole in the right end cap at the back of the deck. This gives you access to the tension bolt. Turn the wrench counterclockwise no more than a 1/4 turn at a time to decrease tension or the opposite way to increase tension. Do not tighten more than necessary to eliminate slippage of the belt on the front roller. You must also then adjust for tracking due to increased belt tension by turning both tracking bolts on each side of the end of the rail 1/4 at a time.
Belt Lubrication Sole treadmill belts come pre-lubricated, but after the first 50 hours of use you will need to lubricate the machine again. Use only lubricant sold by Sole. The treadmill can go for another 1,000 hours of use before another lubrication if it is cleaned regularly. If the belt is running slow and you have done everything else, it may be that your belt is ready ahead of schedule. Spread an entire tube width-wise across the center of the deck. The place where your feet hit when walking or running is the ideal location for the lubricant.
Posted on Oct 16, 2013
maxtreadmill
  • 832 Answers
SOURCE: belt wont start on a brand new Sole F80. Motor
It sound like the motor control board is the culprit. Unplug unit then remove shroud then find the 2 leads that connects the motor to the motor control board disconnect them then plug in unit and see if the display blackout after programing the display then hitting start.
Posted on Mar 13, 2010
maxtreadmill
  • 832 Answers
SOURCE: SOLE F80 TREADMILL STARTS TO RUN THEN STOPS.
Sound like a speed sensor adjustment here the steps for this procedure:
1. Unplug unit then remove the plastic motor cover. There are either 4 or 5 screws holding the cover in place depending on the model.
2. Locate the speed sensor between the front roller pulley and the frame of the treadmill. It is a small plastic piece approx 1 1/4” long and 1/4” in diameter with a black wire coming from the back of it leading to the electronic board in the motor compartment .
3. Locate the magnets mounted in the face of the pulley. (approx. 3/8” in diameter) 4. The end of the sensor should be positioned approximately 1/8” from the magnet at the closest point.
5. Follow the wire from the sensor to the control board. Make sure the connection is pressed firmly down on the board.
Posted on Apr 26, 2010
  • 218 Answers
SOURCE: my treadmill does not incline
incline motor has failed and needs replaced
Posted on Aug 14, 2010
  • 33 Answers
SOURCE: my sole f63 treadmill shows an elevation error and
pls do re-calibration
Posted on Dec 11, 2010
  • 33 Answers
SOURCE: Our Sole F63 treadmill is
pls make clear , countdown is come or not, if coming means problem with controller
Posted on Feb 19, 2011
Just bought sole f63 runs data press start nothinges e4 is displayed then not happy
If you wish to get some details about treadmill repair and error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 07, 2016 | Sole Fitness F63 Treadmill
Shows LS1low speed treadmill stops working what is the solution
hi check the video
Sole F80 LS1 Error
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience
Nov 16, 2015 | Sole Fitness F63 Treadmill
Sole F63 Treadmill Incline Error
http://electro-medical.blogspot.com/. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience
Jun 26, 2014 | Sole Fitness F63 Treadmill
Sole E55 console display flashing "Need Lube"
Got a Sole elliptical machine? Is it displaying a NEED LUBE error message when you turn it on? Tyler at Sole service told me this is a software bug. It appears every 180 miles of usage, and it was really only intended for treadmills, not ellipticals.
You can clean and lubricate the rails and wheels - and you should - but the error message won't go away. Instead, you can get rid of it by resetting the odometer. First, press and hold the Start, Enter, and Stop buttons for five seconds to enter engineering mode. Use the arrow keys to select FUNCTIONS, then select ODO RESET and press Enter. Turn the machine off and on again, and voila, no error message.
Thanks Tyler! Happy exercising!
Jul 06, 2013 | Sole Fitness Sole E55 Elliptical
Error code of ls1 on sole f80 treadmill
John what are you talking about. All that's gonna do is give a LS error is you disconnect the motor.
Aug 22, 2010 | RTO Sole F80 Treadmill
Belt wont start on a brand new Sole F80. Motor
Mar 12, 2010 | RTO Sole F80 Treadmill
Exercise & Fitness Logo
295 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
