Question about Lexmark T630 Laser Printer
Error code 201 lexmark t630 - Lexmark T630 Laser Printer
    Problem Solver:
  • 35 Answers
201 is a paer jam message generated by the fuser (hot thing in the back of printer) remove rear door and the redrive unit. ( two screws on back of printer and press in two levers on upper portion of back to remove) either the switch on the left of the fuser is stuck or the switchneeds replacing (assuming it is a false paper jam)
Posted on Aug 05, 2014
All Office
  • 58 Answers
SOURCE: Lexmark error codes
Too many to list here. Try justmanuals.com, you can get the service manual for about $10.
Posted on Jan 22, 2008
HandyManny
  • 4 Answers
SOURCE: printer problem
Hello, it is likely that the transfer roller requires replacing. You may be able to purchase the roller from a local office supply, otherwise buy on line. However, there is more to it...
The error means, the Transfer Roll Cannot start servo operation. Verify correct cable connections from the Engine board to the HVPS (high voltage power supply). Make sure there is continuity between the transfer roller and its contact on the HVPS; replace the transfer roll if the continuity is correct.
If there is no continuity, make sure the HVPS contact returns to its upward limit when depressed, and make sure the left bearing of the transfer roll is making proper contact.
If the wires are all connected correctly, and there is continuity through the roller contacts, replace the roller.
Posted on Feb 23, 2008
don_farr
  • 1018 Answers
SOURCE: Lexmark T630 has a 933 error. I have replaced the
933 - Mirror Motor - Locks/Lost Hsync* (*Horizontal Sync) Have you gone through this exercise yet: These errors usually indicate a failure in the HYSNC signal to the printhead. Check the continuity of the cables connected to J5 and J4 on the system board. If incorrect, replace the defective cable. The voltage at J4-1 measures approximately +5 V dc. If incorrect, replace the system board. The voltage at J5-7 measures approximately +24 V dc. If incorrect, replace the system board. If correct, replace the printhead assembly. Don
Posted on Jun 07, 2009
  • 320 Answers
SOURCE: Error 32 Unsupport Print Cartridge Lexmark T630
on the inside of the top cover on the left side when the door is open there is a little switch youll see a little metal tab 5/16'wide push on this and see if the error clears. if it does this can be adjusted. if not pull the cartride out there are two sensors on the right inside one close to the front this is an optical sensor blow this out with canned air if you dont have an air compressor. then further back inside there is a two pin sensor make sure that if you push in on these that they dont stick. next there is a smart chip on toner caartridge that lines up with those pins when its installed clean these contacts. doing all of these things usually geets rid of the problem. no parts have been replaced recently right? check the connector to the logic board this is theeonly 3 pin connector that has black and white wires. this sohlud fix your problem
Posted on Nov 28, 2009
SOURCE: lexmark E 342 n paper jam with error code 201
I have a lexmark 342n that the paper jams before it reaches the fuser what could be the problem.
Derek Walters
Posted on Jan 12, 2010
I keep getting a paper jam 201 every time I print. Then I have to open it up and take out the cartridge. What is causing the paper to jam?
A 201 paper jam error indicates the paper did not reach the fuser sensor within the proper time period. This usually indicates the fuser has a problem and needs to be replaced. The part number for the fuser is 56P1333 and it is user installable. You can get one from many places online such as Amazon.com
Aug 20, 2012 | Lexmark T630 Laser Printer
THE PRINTER GIVES ERROR MESSAGE 201 PAPER JAM REMOVE CARTRIDGE . TRIED TO CLEANED THE SENSORS & ALL THE COVER FITTINGS ARE CORRECTED BUT STILL THE ERROR IS APPEARS WHILE PRINTING . THE PAPER IS GET...
The fuser sensor may look ok, but if you pull off the back cover and study closer, you may find that the lower half of the right toggle sensor is broken, leading the sensor to "think" that is is stuck in the open postition. As a temporary fix, unplug that sensor from the fuser board. Ultimately you will have to replace that switch, and that is a hard part to find unless you replace the fuser unit.
Apr 26, 2011 | Lexmark T630 Laser Printer
How do I fix a 922 fuser error on my Lexmark T630?
I'm afraid replacing the fuserunit is the only option.
Feb 24, 2011 | Lexmark T630 Laser Printer
My printer lexmark e342n 201 jam error code, what the are problem, fuser or pick-up roller and how to soft that problem. tq
If you are getting 201 error code, it means a paper jam has occurred. To fix this problem please Open the front door. Remove the toner cartridge and remove the jammed print media.
Click on the link http://bit.ly/p1jJcd to see instructions on how to go about the procedure.
For further assistance, please contact Lexmark Technical Support.
Jan 22, 2011 | Lexmark E342n Laser Printer
Lexmark t630 error says remove paper standard bin. Never knew anything about standard bin -- can't get it to print, and yes, there is a connection to the computer
The Remove Paper Standard Bin error can be possibly caused by the exit flag that is out of position, stuck or broken. Follow troubleshooting steps found at http://bit.ly/dhOTEo. If any part of the flag or holder appears to be broken, contact Lexmark technical support or a local authorized service provider.
Sep 20, 2010 | Lexmark T630 Laser Printer
Lexmark T630 Error message "Paper Jam Remove rear cover." No paper jam...
Open the rear, there is one of the paper sensor actuators stuck. They are spring loaded and should spring back when pushed out by the paper.
Oct 14, 2009 | Lexmark T630 Laser Printer
I am getting a message on the printer that says, "932 Service Printhead Error". The printer is a Lexmark T630. Help
The message indicates that the laser scanning head is defective. Lexmark calls it a printhead. Unless you want to spend a lot of money, it may not be worth fixing. A new part runs over a hundred dollars.
Dec 01, 2008 | Lexmark T630 Laser Printer
Lexmark error codes
Jan 14, 2008 | Lexmark T642 Laser Printer
Lexmark T630 Laser Printer Logo
99 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
