Question about Kirby G5 Bagged Upright Vacuum
I need to change the belt on the shampooer. the shampooer doesn't come apart like the vaccuum unit. i can't get the brush off so i can put a new one on.
I can't get the brush cylinder off the kirby shampooer so that i can put on a new belt
  • 357 Answers
My vaccuum cleaner doesn't come on
as in no pwer change fuse brush roller not revolving check drive belt and replace with new if ness
Jun 07, 2012 | Oreck XL® Classic Bagged Upright Vacuum
Need help putting my bissell carpet shampooer back together
the side that is dragging needs the roller that the brushes are on ,to be precisly pushed back up in it's place,it will take a few minutes and it will not slide back in place easily just use a little force as for the hose diagram, bissell.com,enter model number and go to hoses.
May 31, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
How do you change the belts on a hoover wind tunnel vaccuum
Flip the vacuum over push the pedal so the vacuum lays flat on the floor or table. Remove the four silver screws at all four corners of the brush area. Pull up on the plastic cover and remaove it. Lift the brush out towards you if this is a self propelled unit there will be two belts one will stretch one won't the non stretch belt rarely needs to be replaced and usually indicates another problem. Take a new stretch belt and loop it around the metal shaft and then the brush roll use two hands to push the brush back into position give it a spin to make sure everything is spinning freely then replace the cover. In the case of a self propelled model the stretch belt spans the metal shaft and one of the drive wheels. For belts,bags or questions visit www.stevessewandvac.com
Aug 12, 2008 | Hoover Vacuums
Belt problem
the brush is jammed most likely or not in correctly
Aug 08, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Dirt Devil vacuum sucks... figuratively
Well, I guess your visitors have come and gone, but the vacuum remains the same. It sounds like you have a broken or worn belt. The belt should be changed once a year (approx) and can break if something is picked up that jams the brush. It is also possible that you have something obstructing the vacuum inlet at the brush housing.
If the belt is worn, it can still look o.k., but won't have the tension to turn the roller when it engages the carpet. I suspect the belt is your trouble.
Mar 21, 2008 | Vacuums
Belt removal Bissel PowerSteam ProHeat
First take off the cover on the left side oif the top cover, then turn it over, remove the screw holding the red lock and pull the cap and brush roll out, remove the cap, remove the cogged belt, then you can put the new pump belt thru that slot, put over the pulley on the pump and then stretch it to go over the motor shaft. Then put back together.
Jan 18, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Kirby vaccuum
Make sure that the brushes on the shampooer tray are spinning, that the belt is resting on the driveshaft. The suction alone will pull up some of the moisture but the brushes should be spinning to gently scrub the carpet and deposit any excess moisture into the tray.
Dec 23, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Need help putting back together
With out seeing it, it will be hard to figure out what isn't right. Must be a different model then 1699. which model is it?
Nov 08, 2007 | Bissell 1699 ProHeat Clear View Upright...
Vacuum brush roller with belt attached is off
It is meant to come apart for cleaning it up afterwards. Slip the belt over the roller. One triangular end of the roller is bigger than the other, so keep this in mind when sliding it into the cleaning head. Turn the knob to pick up the belt, just like on the vacuum's regular nozzle. Mount the cleaning head, then turn the knob to set the belt onto the motor spindle.
Apr 02, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
142 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
