Question about Lewis N. Clark Industries Lewis N. Clark TSA80 Lockdown Triple Security Lock
Can't open Lewis n Clark TSA80 lock. Basic instructions, also for resetting forgotten 3-digit code, please!
Need instructions to open Sandleford Digital Safe N15115 RX2009 106 485.
Hi Leanne
Try this is contacting them direct.
Sandleford Digital Safe Instructions
www.sandleford.com.au/Content/images/.../sandleford/DS200_250_300_500_230.pd...
6. Door Handle. 7. Battery Compartment. 8. Locking Bolts. 9. Reset Button. 1. 2. 3. 4. 5. 6. 7. 8. 9. 0. #. *. 3. 7. 8. 9. 21. 4. 5. 6. DIGITAL SAFE. INSTRUCTIONS ...
How to reset code on an electronic safe - YouTube
? 1:04
https://www.youtube.com/watch?v=_tqTp57YfCw May 11, 2013 - Uploaded by donutdaveyboy
How to open a digital safe without any tools or keys IN 2 SECONDS! - Duration: 2:19. Firealarm102 131,330 ...
How to open digital safe when battery is flat and key not working ...
? 1:15
https://www.youtube.com/watch?v=aqC9V7SDKdQ Nov 9, 2012 - Uploaded by khthhonl
How to open a digital safe when the battery is flat and the key does not work? This method takes less than a ...
Sandleford Digital Safe N15115 Google Search
Apr 24, 2017 | Locks & Locksmithing
Tip
Lock Code, Pin Code & PUK code
Lock code: 1. 5 digits, Used to prevent unauthorized access to certain functions on the phone 2. Where: Tools > Settings > Security > Phone & SIM 3. Default: The default lock code for Nokia Series 60 devices is 12345. 4. Forgotten - If you've changed this code and forgotten it - you will need to visit a Nokia authorized service center, who will be able to reset the lock code for you. PIN code 1. 4 digits, an optional 4 digit code to protect your SIM 2. where: Tools > Settings > Security > Phone & SIM 3. Forgotten -If you keep trying, you'll eventually get locked out and need to contact your network operator for a PUK code PUK code 1. 8 digits, You'll be asked for this 8 digit code if you've entered the wrong SIM code more than the allowed number of times. You'll need to contact your network operator to get this lock lifted.
on Jul 30, 2007 | Nokia E61 Smartphone
Says code error
How To: Open A Locked Sentry Safe If You Forgot ...
? 5:21
https://www.youtube.com/watch?v=Mr8QrvVAtuI
Jul 15, 2014 - Uploaded by TipsNNTricks
I show you How To Open A Locked Sentry Safe If You ForgotThe Combination Or Loss Your Digital Code Or Lossed Your Key. The Sentry Safe ...
' Sentry® Safe ' Lost Your Combination
https://www.sentrysafe.com/.../Lost_Your_Combination
Sentry GroupCombo Recovery. What you'll need: Model Number; Safe Serial Number; Notarized Statement of Ownership. Step 1. Safe Info. Step 2. Notary Form. Step 3
opening a electronic safe forgotten the lock code ready to ...
www.instructables.com/.../OPENING-A-ELECTRONIC-SAF...
InstructablesJul 6, 2009 - I HAVE A SAFE GAURD COMPANIES SAFE I HAVE FORGOTTEN THE LOCK CODE TO OPEN IT. THEIR IS NO ALTERNATIVE OF KEY ...
How to Crack a Safe (with Pictures) - wikiHow
Jan 10, 2016 | Home Security
How do i reset a lewis clark luggage lock if i forgot the combination
I did these:
1) Apply continuous pressure on the tip of the long cable as if you were trying to unlock it. Do it softly, pain would block your sensitivity.
2) Turn the first dial (the closest to the long cable) slowly, as many times as you need, until you feel there is one number where the tip feels slightly (hardly noticeable) loose. Stop there.
3) Do the same for the second dial.
4) For the third dial press the tip of the short cable instead, and do the same as in step 2.
5) Very likely it will open, but if it did not, leave the dials in the position you found and start again. If at least one of your dials is correct, detecting differences will be easier.
Hope this helps.
Jul 18, 2014 | Lewis N. Clark Industries Lewis N. Clark...
Unlock pacsafe 100 have forgotten code
How do I reset the combination?
Instructions are included with every combination lock, however if you have lost them, please refer to our instructions which can be downloaded at the respective product page. If you have set the combination once, you will need to remember this combination when resetting again (i.e. replace the 0-0-0 in the instructions with the combination you chose).
Apr 09, 2013 | Pacsafe Daysafe 100 Travel Backpack in...
I bought a roadster combination spiral lock. there are no instructions, so I can't change the setting from the default setting
I bought one today and the shop told me what to do: assuming you have the lock open...
Look down the end with the hole where there is a knurled knob inscribed "reset" on the end with an arrow . Turn to the right - clockwise - following the arrow. Now set the new number you want. Then twist the knurled knob back to the left... and you've done it!
Robert Clark
Aug 23, 2012 | Locks & Locksmithing
We have a Passage-2 luggage lock that my husband has forgotten the 3 digit code to. how can we reset it to get it unlocked and set up with a new combo?
if you have forgotten the combo the only way to get the lock to open is to ' progress ' the combo wheels. since it is only a 3 digit combo - this will take anywhere from 15 to 40 minutes.
start with 000 then 001 then 002 etc... all the way to 999 ( but you will get the combo before 999 is reached ). after the combo is found, with the latch open push the lever to the to open position and set the new combo that you want.
c...
Jan 15, 2011 | Locks & Locksmithing
I cannot open my sons Science Museum Lock N safe Money Box
here is the default code, start by pressing mode so you go into code mode, tehn turn the dial left to 0, then right to 1, then left left 0,then right to 3 then turn dial right and your safe will open!!!!!
Jan 15, 2009 | Toys
Lewis N. Clark Industries Lewis N. Clark TSA80 Lockdown Triple Security Lock Logo
174 people viewed this question
Top Lewis N. Clark Industries Luggage & Travel Experts
Dave braun
Dave braun
Tom Chichester
ray gallant
Are you a Lewis N. Clark Industries Luggage and Travel Expert? Answer questions, earn points and help others
