Question about Horizon Fitness Horizon Motor T51 (treadmill)
The motor will not move - Horizon Fitness Horizon Motor T51 (treadmill)
    Top Expert:
  • Horizon Fitness Master
  • 12,223 Answers
Test voltage from output control board motor, for input voltage terminal motor, if there ARE not voltage, the control board is faulty.
see my personal TIPS for motor.
2) test the terminal voltage motor, if there ARE the motor is faulty.
3)loose the belt and try again if the motor is running the problem is the deck belt board, LUBE it.
God bless youthe motor will not move - 356531a7-34d7-49c5-b4b2-83d2982da514.gif
Posted on Oct 16, 2013
Steering wheel wont move right or left engine wont move don't want to force it
inboard or outboard motor ??
unbolt the steering cable from the steering point of the engine or leg unit , then try turning the wheel and if it moves then try moving the engine or leg unit and see if it moves !?
Mar 27, 2015 | Boating
Laser step motor dont move
can be varios reason: 1) faulty motor 2) control motor defective 3) lube in shaft motor 4) mechanical device for motor defective.5) Syscom (microcontroller defective) see the block diagram
Jul 13, 2013 | Pioneer CDJ-100S CD Player
Merc c 180 elegance. Wiper is not moving but i can hear the motor.How do you replace the motor.
Probably not the motor if you can hear it, its probably the regulator, meaning the mechanisim the motor tuns to move the wipers. When you find the motor, pull it off, and make sure the regulator moves freely without the motor engaging it.
Mar 08, 2013 | 1997 Mercedes-Benz C-Class
2004 tundra windshield wipers don't move but motor runs
If both wiper arms move, the linkage between them probably is OK. What isn't OK is the connection between the arms and the motor. You will have to get access to the motor area to find out what needs repair
Dec 27, 2012 | 2004 Toyota Tundra SR5
The vents on the driver side only blows hot air while the other vents work properly when using the ac
This is common on daulzone heating /ac systems.this unit uses separte doors to control the temp on the driver and pass/sides. your problem is a bad blend door motor. i will see if i can give you some pictures and diagrams of what im talking about to help you locate and repair this problem. the first step would be to locate the bad motor. there are about four motors that control difffrent functions, you will need to locate them one at a time, next is watch one motor then start moving the controls, for example hot to cold then air flow settings and also hit the recirculate button for inside air flow or outside air flow and you want to see if this motor moves and if it does then thats not the motor. you will see when you move a control what the motor does. you will do this with every motor once you see the motor or also called actuator move you dont have to keep moving the controls you then move on to the next motor, you will do this until you locate the one that doesnt move and that will be the bad motor which will control the air flow for the driverside. the motor itself wont move but you will see the linkage move or the tab. i will show you what the tab is. the motors are all located on the heaterbox and held in by screws, this is under the dash, you dont have to remove the dash just a cover if its covered. good day.johnjohn2_129.jpgjohnjohn2_145.gifjohnjohn2_146.gif
Aug 20, 2011 | 2004 Chevrolet TrailBlazer
The seat tilt moves forward but not back. thus I am stuck all the way forward. Is there an override or manual way to tilt the seat back??
All the motors under the seat are bi-directional, meaning you can apply power (12V) on one side and ground on the other, it will turn in one direction. If you reverse the wires it will move in the opposite direction. Quite often the motors fail, but if it at least works in one direction it's usually a wiring issue. Follow the wires from the failed motor to the connector, and jumper them both. The motor should move backwards, and you'll have to find the problem in the wiring. If it doesn't move, lightly tap on the motor with power and ground supplied, if it now moves the motor is starting to fail
Feb 13, 2011 | 2003 Chevrolet Suburban
Power mirrors not working, have tried moving them manually (2001 Ford Crown Victoria). Both sides only goes down, not up.
If the mirrors only move down and not up I would suspect the mirror switch , the mirrors use one motor to move the glass up and down,and another motor to move them in or out , and if the mirrors move down the motors are working.the only other possible problem would be a wiring but highly unlikely due to the fact that the turning the motors in a different direction is done by switching the polarity to the motor which requires both wires to be good to make the motors move in the down direction ..check the mirror switch I am sure you"ll find that"s your problem
Dec 29, 2010 | 2001 Ford Crown Victoria
Driver door window will not move. The motor makes
possible broken motor cable or motor gear that move your window up and down, need visual inspection...
Feb 03, 2010 | 1994 Toyota Camry
2000 taurus hear motor but arms dont move. i can
it sounds like the wiper transmission has broken/slipped off of the wiper motor. Remove wiper motor and check wiper transmission.
Dec 26, 2009 | 2000 Ford Taurus
Craftsman opener motor works, but chain does not move.
If the motor is working but the chain does not move you must remove the cover on the motor and check to see that the chain is on the sprocket. If the chain is on the sprocket and the sprocket is not moving but the motor shaft is moving then the sprocket must be retightened onto the motor shaft.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Horizon Fitness Horizon Motor T51 (treadmill) Logo
178 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Craig Butler
Craig Butler
wtdash
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
